2 Replies Latest reply on Jul 4, 2014 5:54 AM by fargois
    Unable to open catalog
    fargois
      After upgrading to LR 5.5 I had to recover to a previous date and in the process ended up losing my 5.5 and reverting back to 5.4.
      Now when I try to open LR, I get an error msg that states  Unexpected error opening the catalog.  I have the options to retry, choose a different catalog or to exit
      Of course when I retry the same thing occurs, when I try  Choose a different Catalog a different windows opens and gives the choice of either choosing a different
      catalog or to create a new one.  I am unable to do either one.  I am pretty certain its user problem and need a little help if you can
      Tony
        • 1. Re: Unable to open catalog
          Brett N Adobe Employee
          If you are unable to create a new catalog, then the problem probably isn't that your catalog is broken. More likely is that whatever problem you had with 5.5 is still present on the system or you were not able to cleanly remove LR5.5 and some piece of it is interfering with LR5.4. I'd suggest running through the uninstall process for LR and then delete any left over application folders and clearing out the preference files (don't delete you catalog, but that shouldn't be an issue as it is stored in a completely different place, by default).
          • 2. Re: Unable to open catalog
            fargois Level 1
            Thanks for the suggestion.  I finally resolved the issue by DL the 5.5 from the Lightroom website
            And installing it. That seems to have resolved the issue since I can now open LR.
            I appreciate you responding to my question, your suggestion that some piece of 5.5
            Lingered after the recovery of the computer pushed me to doing the update to 5.5
            Directly from the website.
            Thanks again
            Tony
            Tony Vecchi
            tia cert
            Photo Album located at:
            <http://home.comcast.net/fargois/index.html> http://home.comcast.net/fargois/index.html  (last updated 05-28-14)
