9 Replies Latest reply on Jul 6, 2014 8:08 PM by hasvi
    Script Running time log report
    hasvi Level 1
      Is there any possibilities to take the run time report for script running process. For instance I have to collect my script running time to close time as in log report.
      by
      hasvi
        • 1. Re: Script Running time log report
          Chinnadk Level 4
          Hi Hasvi,
          Try this.
          var start = new Date().getTime();
          //Your scripts goes here.
          var end = new Date().getTime();
          var time = end - start;
          alert("Execution time in seconds: " + time/60);
          Regards,
          Chinna
          • 2. Re: Script Running time log report
            Jump_Over Level 5
            Notice that time is a number of miliseconds, so it supposed to be:
                 alert("Execution time in seconds: " + time/1000);
            Jarek
            • 3. Re: Script Running time log report
              hasvi Level 1
              I have check with one script, finally its showing alert message "Execution time in seconds: 338.258". Suddenly I can’t understand this time, is there any easy way to get time "Hours: Minutes: Seconds"
              See below the calculation and its Result:
              alert("Execution time in seconds: " + time/1000)-->Execution time in seconds: 338.258
              alert("Execution time in seconds: " + time/60)-->Execution time in seconds: 6345.05
              by
              hasvi
              • 4. Re: Script Running time log report
                Chinnadk Level 4
                var seconds = Math.round(time/1000),
                var minutes = Math.round(seconds/60);
                var hr = Math.round(minutes/60);
                alert(hr + ":" + minutes + ":" + seconds);
                • 5. Re: Script Running time log report
                  hasvi Level 1
                  Error showing "Illegal use of reserved word 'var'
                  on line "var minutes = Math.round(seconds/60);"
                  FYI:
                  by
                  hasvi
                  • 6. Re: Script Running time log report
                    Chinnadk Level 4
                    var seconds = Math.round(time/1000);
                    • 7. Re: Script Running time log report
                      hasvi Level 1
                      I really admire your script. Thanks chinna
                      by
                      hasvi
                      • 8. Re: Re: Script Running time log report
                        Jump_Over Level 5
                        Hm... this code say true only for time lower than 1 minute (< 30 sec in fact, since round goes up).
                        Notice that number of hours, minutes and second should be calculated as a PARTS of a bigger sum.
                        Otherwise adding hr + minutes + seconds gives us a time 3 times bigger (more or less around).
                        So,
                        var
                            end = new Date().getTime(),
                            time = end - start,
                            mH = ("0" + Math.floor(time/3600000) ).slice(-2),     //     upto 99 hours be awared
                            mM = ("0" + Math.floor( (time%3600000) / 60000 ) ).slice(-2),
                            mS = ("0" + (time%60000) / 1000).slice(-2);
                        alert(mH + ":" + mM + ":" + mS);
                        Jarek
                        • 9. Re: Script Running time log report
                          hasvi Level 1
                          1. I had run the below script:
                          var myDocument = app.activeDocument;
                          myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.inches;
                          myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.inches;
                          myDocument.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
                          myDocument.textPreferences.superscriptPosition=33;
                          myDocument.textPreferences.superscriptSize=70;
                          myDocument.textPreferences.subscriptPosition=33;
                          myDocument.textPreferences.subscriptSize=70;
                          myDocument.textPreferences.smallCap=75;
                          app.imePreferences.inlineInput=true;
                               result is 0:0:0. because its running running within fraction of seconds.
                          2. I had run the below script
                          var
                              time = end - start,
                          result is 00:00:19. Heare what is 19, because this script is running within fraction of seconds.
                          by
                          hasvi
