- I have a webapp field entitled "Status".
- I have a webapp fields entitles "Status-Listed".
- I want to have a tag in the description field that is {tag_Status-{tag_Status}} to where if the Status field is set to Listed the result will be {tag_Status-Listed} and will return the value in the Status-Listed field.
- It works, and returns the value:
<h2>Listed</h2>{tag_county} County<br />{tag_firstname} {tag_lastname} | {tag_address1}, {tag_address2} {tag_city}, {tag_state} | {tag_zipcode} | {tag_phone}<br />{tag_status} | <em>
- However, this will display as the text entered when the tag is rendered from Design view. If I place the code in the HTML view it will render each tag correctly. What I am seeking to do is apply four different types of stylings to the listing, as in Listed, Not Listed, Rejected, No Answer, etc. That way in my directory I can have the status determine the type of look each listing has based upon the Status field.
Any thoughts from the community?
I am not sure I follow what you are explaining, but, I will try to give you an idea. Wrap all of your HTML in a div with a class of {tag_Status-{tag_Status}}. you can then style as necessary. However, if this involves hiding certain elements, then I would suggest using a custom template for each type of listing.
