4 Replies Latest reply on Aug 16, 2016 3:49 PM by RampantShadow
    Platform conversion failed error during release build
    FranzBan
      This is a very annoying problem while generating release build files. Here is the steps I did while buiding:
      1. Select Project > Export Release Build
      2. Select Signed Native Installer
      3. Import certificate
      4. Click Next.
      I always got the following error:
      I have the following setup:
      OS: Windows 8.1
      System type: 64-bit
      Flash Builder Version: 4.6 Premium
      Installed FB: FlashBuilder_4_6_LS10.exe
      Please help. This is giving me a lot of headaches for a couple of days now.
        • 1. Re: Platform conversion failed error during release build
          FranzBan Level 1
          Additionally, here's the stack trace:
          java.io.IOException: Platform conversion failed. Process exited with error 5. Output was "[ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
            at com.adobe.air.nai.NativePackager.conversionFail(NativePackager.java:222)
            at com.adobe.air.nai.NativePackager.invokePlatformConversion(NativePackager.java:203)
            at com.adobe.air.nai.NativePackager.createPackage(NativePackager.java:92)
            at com.adobe.flexbuilder.multisdk.apollo.export.AIRNativeInstallerPackager.create(AIRNativeI nstallerPackager.java:129)
            at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionManager.doExport(Ex portReleaseVersionManager.java:586)
            at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard$1.run(Exp ortReleaseVersionWizard.java:208)
          Message:
          I also suspect this is because of the following settings:
          Eclipse.ini
          FlashBuilder.ini
          Please click the image for more clearer view.
          Notice that the plugin used is not intended for x64 processors.
          Please help.
          • 2. Re: Platform conversion failed error during release build
            FranzBan Level 1
            I see this similar issue reported in Apache Flex but not yet fixed:
            [FLEX-24594] ADT fails with exit code 5 (Unknown error) - ASF JIRA
            • 3. Re: Platform conversion failed error during release build
              FranzBan Level 1
              I tried installing windows 7 32-bit operating system and I no longer have problems on exporting release builds. I'm just wondering if Adobe released Flash Builder 4.6 for x64 operating systems.
              • 4. Re: Platform conversion failed error during release build
                RampantShadow
                In case any one finds this later on, I had this same issue but I fixed if by re-linking my Library Path files (even if they look correct they don't seem to connect for some reason) this resolved my issue, hopefully this is easier to do than re-installing or installing a fresh operating system to get it done.
