4 Replies Latest reply on Jul 5, 2014 12:02 PM by A.T. Romano
    Saving project as MP4 file or .mov file
    kevinbwatkins
      I want to burn my finished project as a DVD but my burning program needs it to be in a .mov or MP4 format. Can I save my project as such??
        • 1. Re: Saving project as MP4 file or .mov file
          A.T. Romano Level 7
          kevinbwatkins
          What version of Premiere Elements are you using and on what computer operating system is it running?
          Did you produce a DVD-VIDEO on DVD disc or AVCHD format on DVD disc? If, DVD-VIDEO, was that DVD-VIDEO standard 4:3 or
          DVD-VIDEO widescreen 16:9?
          For now, assuming Premiere Elements 12/12.1 on Windows 7, 8, or 8.1 64 bit and assuming that you want the file to reflect the resolution
          of the DVD-VIDEO (presumed widescreen in this example)
          for the .mp4
          Publish+Share/Computer/AVCHD with Presets = MP4 NTSC DV Widescreen - using default export settings
          for the .mov
          Publish+Share/Computer/QuickTime with Presets = NTSC DV 16:9 - using default export settings
          With details, we can fine tune what you seek.
          We will be watching for your follow up.
          Thank you.
          ATR
          • 2. Re: Saving project as MP4 file or .mov file
            kevinbwatkins Level 1
            Thanks for the response. Actually, what I need to do is to save the file to
            my harddrive with a MP4 or .mov extension. I need it saved with this
            extension so that I can burn it to a DVD using Nero Burning Rom software.
            Is there a way to save the project file as a MP4 or .mov file??
            On Sat, Jul 5, 2014 at 12:53 PM, A.T. Romano <forums_noreply@adobe.com>
            • 3. Re: Saving project as MP4 file or .mov file
              I forgot to add that I'm using Adobe Premiere Elements 11.
              On Sat, Jul 5, 2014 at 1:05 PM, Kevin B. Watkins <
              • 4. Re: Saving project as MP4 file or .mov file
                A.T. Romano Level 7
                kevinbwatkins
                Thanks for the reply.
                The project file is the project.prel. You cannot change the project file (project.prel file) into a project.mp4 or project.mov file.
                But, what is possible is to export the Timeline content of that project.prel file to a file whose format has a .mp4 or .mov file extension.
                For Premiere Elements 11 on Windows 7, 8, or 8.1 64 bit, I would suggest
                for the .mp4
                for the .mov
                If you have a HD source on your Timeline and your destination is a DVD-VIDEO widescreen on DVD disc, you forced into the
                properties of the DVD-VIDEO product, namely 720 x 480 16:9 @ 29.97 interlaced frames per second (with 16:9 flag stretching
                the 720 x 480 to 856 x 480 for display after encoding).
                But, if you have a HD source in this project that just produced the DVD-VIDEO widescreen on DVD disc, you can opt to export
                a file with the same resolution as the DVD or export to a file with a resolution comparable to the HD source. Please clarify and
                we can fine tune the suggested export setting accordingly.
                Thank you.
                ATR
