0 Replies Latest reply on Jul 5, 2014 10:31 AM by Mohit M Chavda
    Can we change in SDK files ?
    Mohit M Chavda Level 1
      Hello,
      I am using Flex SDK 4.0.0 in my Web application.
      I have face one issue with Advanced Data Grid.
      When i have given variable row height and row height will be set in Advanced Data Grid Column renderer .
      But when i have scroll vertically then AdvancedDataGridBaseEx class throw an error for null reference object.
      I have found that measuringObjects is null in below function.
      mx_internal function getMeasuringRenderer(c:AdvancedDataGridColumn, forHeader:Boolean, data:Object):IListItemRenderer
              var factory:IFactory = columnItemRendererFactory(c,forHeader,data);
              var item:IListItemRenderer = measuringObjects[factory];
              if (!item)
                  item = columnItemRenderer(c, forHeader, data);
                  item.visible = false;
                  item.styleName = c;
                  listContent.addChild(DisplayObject(item));
                  measuringObjects[factory] = item;
              return item;
      While i am checking in Flex SDK 4.6.0, i have found that null measuringObject is track and solved.
        if (!measuringObjects)
                measuringObjects = new Dictionary(false);
              if (!item)
                  item.styleName = c;
              return item;
      => I don't want to use Flex SDK 4.6.0.
      => can i directly update in Flex SDK 4.0.0 AdvancedDataGridBaseEx class ? ( i have done but it is not working)
      => can any one have solutions ?
      Mohit
