1 Reply Latest reply on Jul 5, 2014 1:54 PM by ssprengel
    sharpening
    2augs
      When I sharpen a photo under "Develop", the sharpening is gone when switch to "Library".  My other edits remain.  Please advise.  Thanks
        • 1. Re: sharpening
          ssprengel Adobe Community Professional & MVP
          You’re probably judging the sharpening at Fit or other reduced-size zoom.  You should only judge sharpening at 1:1 zoom, as the warning exclamation-point indicates in the Detail area if you’re not a 1:1.
          Does sharpening in Develop and Library look different when you zoom to 1:1?
          Sharpening needs to be judged at 1:1 because the resampling-for-the-screen methods LR uses in Develop and Library are different due to speed being of utmost importance in Develop and speed of resampling is less accurate.
          LR sharpening is done in two phases, one in Develop in the Detail panel at 1:1 zoom, where you judge the tradeoff between noise-reduction and sharpening.
          The second sharpening is done at Export time after you’ve resized down to what the final size will be.  There is no way to judge Export sharpening be using Fit view in Develop.
