5 Replies Latest reply on Jul 7, 2014 10:23 AM by jbowden
    Referencing symbols from symbol elements
    Tim. Signore Level 1
      Hello,
      What is the correct syntax to reference a symbol ( in order to control its timeline) from a symbol element, when this is returned as the event target. I don't want to hard code this/ use symbol names, just step back from the currently targeted symbol element to reference the symbol that owns it.
      many thanks for any help.
        • 1. Re: Referencing symbols from symbol elements
          Sorry, to be clear, I mean the symbol element as in getSymbolElement(), not an element within the symbol.
          • 2. Re: Referencing symbols from symbol elements
            In case this helps anyone else, I finally achieved what i outlined above using the code below. The stage holds a symbol called allButtons, which holds two symbols, Button1 and Button2. The symbol elements of these are the click targets, and have the class btnClicka.
            $(".btnClicka").on("click", function(e){
              var targetID = e.currentTarget.id;
              var buttonClicked = targetID.charAt(targetID.length-1);
              console.log("click " + buttonClicked);
              sym.getComposition().getStage().getSymbol("allButtons").getSymbol("Button" +buttonClicked).stop("Touch");
            To me, this does not seem like an elegant solution; is it necessary to go all the way out to the stage and back in again to target what I want, when it's only one step away from where I started. Seems like walking round the block to visit the house next door. If anyone knows the shorter/ clever way to do this, I would love to know.
            • 3. Re: Re: Referencing symbols from symbol elements
              jbowden Adobe Employee
              Hi Tim,
              Instead of this:
              Try this:
              sym.getParentSymbol().getSymbol("Button" +buttonClicked).stop("Touch");
              Or even easier (if your button will always be in the symbol that you want to control):
              sym.stop("Touch")
              For more info:
              Adobe Edge Animate CC JavaScript API
              hth,
              Joe
              • 4. Re: Referencing symbols from symbol elements
                Hi Joe,
                Many thanks for your reply. I have tried both of the approaches you suggested; the first gives me this error:
                Uncaught TypeError: Cannot read property 'getSymbol' of null
                The second throws no error, but there is no change(in other words the stop("Touch") command is not executed.
                I have put my test files (very simple) here:
                ButtonsTest.zip - Box
                Would appreciate any light you can throw.
                Thanks again,
                Tim
                • 5. Re: Re: Referencing symbols from symbol elements
                  Sorry, my first reply was outside the scope of the code in compositionReady handler (didn't notice this until I downloaded your file). In this scope, this line (less code) should work:
                  sym.getSymbol("allButtons").getSymbol("Button" +buttonClicked).stop("Touch");
                  This works because the scope is already Stage, so you only need to getSymboll rather than getting the Stage first.
