2 Replies Latest reply on Jul 7, 2014 11:33 AM by Boush
    How to Achieve Dead Eye Effect
      I'm wondering how I can achieve this style of effect using Adobe After Effects. The sepia tint seems easy enough, but how do you get the light flash at the beginning and make the X marks come in (enter large and white then gain saturation and become smaller) as they do?
      Video for reference: Dead Eye | Red Dead Redemption | - YouTube
        • 1. Re: How to Achieve Dead Eye Effect
          The change in color and size of the X can be recreated with a couple of keyframes, one pair for scale, one pair for color. Adding glow and adding keyframes for the properties you want to animate would do that.
          The color overlay, the sepia tint and flash are just layers with blend modes. The flash could be created with a radial blur with the blend mode ADD and animated opacity, the tint change from a colored solid with the blend mode set to Color, or overlay. You could also achieve the tint with an adjustment layer and animated Hue and Saturation set to colorize, then animate the opacity of the adjustment layer.
          If your camera is moving you'll need to do some simple tracking to line up the X's. Each X would be on a separate layer and you could create an animation preset for the color scale and glow change, then set the CTI to the right frame and apply the animation preset.
          This is all very basic compositing and animating techniques. If you do not understand what I am talking about then search the help files for each thing I have mentioned by typing for example, blend mode in the search field at the top right corner of AE.
          • 2. Re: How to Achieve Dead Eye Effect
            Boush Level 1
            Thanks a lot for the answer. It was very detailed and explained everything well, I really appreciated it.
