4 Replies Latest reply on Jul 6, 2014 5:39 PM by A.T. Romano
    When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed
    sojo314
      When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed.  I am using Premiere Elements 12 - the manual says it supports AVI files.  I have DivX Codec.  Why can't I import this video?
      SoJo314
      Also . . . how do you find an email directly to Tech Support?
        • 1. Re: When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed
          A.T. Romano Level 7
          sojo314
          Just a reminder. This is not Adobe. User to User.
          I can give you a link to Adobe via its Adobe Chat whose representative can advise you of your troubleshooting opportunities from Adobe.
          You need to be careful for your choices, since most bounce you back to the forums. Right now the link that should be showing
          Chat
          and
          Ask the Community
          is only offering Ask the Community
          Contact Customer Care
          AVI is just the container/wrapper format that wraps the compression. Some video compression that may be supported may not be supported when it comes wrapped in a particular format. For example, AVCHD is a supported video codec. AVI is a supported file wrapper. But, AVCHD.avi is not supported by Premiere Elements.
          Other .avi files that are problematic for Premiere Elements
          Xvid.avi (you would never want to use that in a Premiere Elements project)
          DviX.avi, problems but probably to a lesser extent that Xvid.
          MotionJPEG.avi
          Some have downloaded and exported the DivX codec so that it would show up in the choice of video codec for an .avi export and have had some success with that on the export side.
          And, factor into all this is the possibility of the codec being installed but not recognized by Premiere Elements (any version).
          I will look into your specific situation if you give the brand/model/settings of the camera that recorded your video. Is what you are trying to import into Premiere Elements raw footage from the camera? Or, have you converted the raw footage from the camera prior to importing it into Premiere Elements? I have not run into a camera that records DivX.avi as suggested by your introductory details.
          Add On....I do not see Xvid nor DivX video compression as supported by Premiere Elements.
          From a computer perspective, you might want to download and install the codec utility named GSpot and see what the file readout shows for Video Name, Codec, Status as well as Audio Name, Codec, Status.
          GSpot Codec Information Appliance
          We will looking  forward to your follow up when you get a chance.
          Thank you.
          ATR
          • 2. Re: When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed
            One... please provide brand/model camera information
            Two... AVI is a wrapper, what is inside YOUR wrapper - Exactly what is INSIDE the video you are editing?
            Codec & Format information, with 2 links inside for you to read http://forums.adobe.com/thread/1270588
            Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
            http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
            Free programs to get file information for PC/Mac http://mediaarea.net/en/MediaInfo/Download
            Three... no direct email that I know of
            Select a topic, then click I STILL NEED HELP to start Premiere Elements Online chat
            -http://helpx.adobe.com/contact.html?product=premiere-elements
            Added... ATR beat me to the post reply button by a few seconds!
            • 3. Re: When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed
              sojo314 Level 1
              Thank you so much for your replies.  The following is further information I should have included the first time . . . sorry.
              The camera is a Canon Powershot SD750
              I am unsure if I am answering the question about what is inside the AVI file correctly but the entire file name is MVI_0245.avi
              The video system on the camera that was used to record is: NTSC if that is important.
              My computer is running Windows 7.  The video will play in Windows Media Player, the mini player within the Elements Organizer and loaded to the Organizer just fine.
              I read a toubleshooting page that said downloading the DivX codec can help sometimes with AVI files.  So I downloaded it and the video plays just fine in the DivX player as well.
              So, I am not having any issues playing the video.  I am having issues importing it from the organizer, my computer, and directly from the memory card to Premiere Elements 12 wherein I get the error "This type of file is not supported, or the required codec is not installed."
              Although I know how to print screen and insert images, I am unable to do so here.  So, I will type in the pertinent info from Media Info:
              Format:  AVI
              Format/Info: Audio Video Interleave
              File Size: 861 MiB
              Duration: 7mn 50s
              Overall bit rate: 15.2 Mbps
              Writing Application: CanonMVI06
              Video:
              Format: JPEG
              Coded ID: MJPG
              Width: 640 Pixels
              Height: 480 Pixels
              Display aspect: 4:3
              Frame Rate: 30.000 fps
              Color Space: YUV
              Chroma Subsampling: 4:2:2
              Bit Depth: 8 bits
              Scan Type: Interlaced
              Compression Mode: Lossy
              Bits/(Pixel *Frame): 1.588
              Stream Size: 821 MiB 95%
              Audio:
              Format: PCM
              Format settings, Endianness: Little
              Format settings, Sign: Signed
              Codec ID: 1
              Duration: 7 mn 50s
              Bit Rate Mode: Constant
              Bit Rate: 705.6 Kbps
              Channel(s): 1 Channel
              Sampling Rate: 44.1 KHz
              Bit depth: 16 bits
              Stream Size: 39.6 MiB (5%)
              Alignment Aligned on Interleaves
              Interleave, duration: 999 ms (29.98 video frames)
              Interleave, preload duration: 1000 ms
              That's it . . . I hope this information helps you let me know if I will be able to edit this video on Premiere Elements 12 and/or what I need to do to be able to and if not . . . do you have suggestions on what program I should use to edit these types of videos.
              Thank you again so much for your help and information.
              SoJo314
              • 4. Re: When I try to import an AVI file from my camera I get an error saying file not supported or required codec not installed
                A.T. Romano Level 7
                sojo314
                The DivX video codec has nothing to do with this matter.
                But, your answer is in the information you sent...in a word (or two), the MotionJPEG video codec Premiere Elements (any version) issue...
                The possible choices for resolution of the issue
                a. If a utility came with the camera, installation of it may provide the necessary MotionJPEG codec.
                b. Download and install a MotionJPEG codec from online, frequently used one is the Morgan MotionJPEG codec. It may be available elsewhere as well.
                http://www.morgan-multimedia.com/morgan/php/products.php?sProductId=4&sProductSub=download s
                Suggest looking at the tryout first.
                c. Convert the MotionJPEG.avi to DV AVI using a 3rd party converter. MPEG Streamclip is an excellent choice. Please let me know if you need the setting for this.
                Squared 5 - MPEG Streamclip video converter for Mac and Windows
                We will be watching for your follow up. In this type of matter, it is a toss up between codec not being installed and Premiere Elements not having the codec available to it.
                We will be watching for your results.
                Thanks.
                ATR
