3 Replies Latest reply on May 7, 2007 9:57 AM by Newsgroup_User
    Changing the value of  a var
    cre8ive1974 Level 1
      I have no idea if I am even asking this right. is it possible to change the value of a var by pressing a button?
        • 1. Re: Changing the value of  a var
          Level 7
          cre8ive1974,
          Sure, you could change the value of a variable by pressing a button, but
          button would have to be programmed to do so. Is that what you're aiming
          for? If so, I can help, but I'll need to know what language you're using,
          ActionScript 2.0 or 3.0.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Changing the value of  a var
            cre8ive1974 Level 1
            I am using ActionScript 2.0
            I have a global variable
            when I click a button I want the varaible to change.
            then based on the change
            I want something to happen based on what that variable is.
            for example the original global var = 1
            then you hit the button and the global var = 0
            then because the global var = 0 something happens
            • 3. Re: Changing the value of  a var
              Level 7
              cre8ive1974,
              Okay.
              By that, I'm assuming you mean a property of the _global object.
              All right.
              Okay, let's say the variable's name is myVar. Then you might have
              something like this:
              _global.myVar = 1;
              Assuming a button instance name of myButton ...
              myButton.onRelease = function():Void {
              _global.myVar = 0;
              Where should this last part go? Also inside the button? If so ...
              _global.myVar = 0;
              // something else here
              ... otherwise, you could use that "other thing" to check the _global.myVar
              property:
              if (_global.myVar == 0) {
              // do something
