I think I may have found yet another issue with our old friend the Glossary interaction.
I've discovered that if you insert the Glossary, select a theme and resize the interaction on screen to make it a little larger (e.g. I resized proportionately from 500 pixels high to 627), then some of the lines from the Definitions get cut off. It's inconsistent where it cuts off and where it shows. But it seems that resizing the interaction does not change the text area allowed to display the definition text. It remains more or less the same size as allowed for that amount of text when the glossary is first inserted.
By the way, I've checked the last modified date on the wdgt file for the inserted glossary and this is definitely a recent version (1/July/2014).
So am I correct in assuming that the designers of this interaction believed that nobody would be intending to resize it on screen?
