1 Reply Latest reply on Jul 8, 2014 5:08 PM by Tom Ruark
    to create plugin using CLI/C
    saket_123
      Hi all
      I had tested the sample-code for Disolve ...
      ...\pluginsdk\samplecode\filter\dissolve
      I placed the dll file "disolve.8bf" in location as C:\Program Files (x86)\Adobe\Photoshop CS6\plug-ins\Disolve and it's installed and running successfully ...
      I need to create a plugin for Photoshop CS6. I had created the UI using Window Form Application template
      Now I had customized the extension as:
      As In Property Page -
      • Configuration properties -> general -> Target Extension as .8bf
      • Configuration properties -> general -> Configuration Type as .dll
      I placed the dll file to C:\Program Files (x86)\Adobe\Photoshop CS6\plug-ins\Disolve.
      Any suggestion will be appreciated, Please suggest me if any tips are there, because reworking these all will take a lot of time ...
        • 1. Re: to create plugin using CLI/C
          Tom Ruark Adobe Employee
          I haven't tried Window Form Application but there is a MFC example that might help you. My guess is that you don't have the PiPL resource in your plugin. In the Dissolve example, notice there is a Dissolve.r file and that file has a custom build step that produces a resource that Photoshop needs to load your plugin. I would review that and make sure your WFA has the same resource as the Dissolve Win32 example.
