4 Replies Latest reply on May 9, 2007 4:49 PM by BLXWebMaster
    Load Data from External .txt file
    compubrook
      <mx:Script>
      <![CDATA[
      import flash.display.Sprite;
      import flash.events.*;
      import flash.net.URLLoader;
      import flash.net.URLLoaderDataFormat;
      import flash.net.URLRequest;
      [Bindable] public var i:int = 20;
      [Bindable] public var tester:int = 0;
      var loader:URLLoader = new URLLoader(new URLRequest("test.txt"));
      private function completeHandler(event:Event):void
      var loader2:URLLoader = URLLoader(event.target);
      var variables:URLVariables = new URLVariables(loader2.data);
      trace(variables.xyz);
      tester = variables.xyz;
      </mx:Script>
      I'm trying to read in data from an external text file. Is there any reason why this isn't working?
        • 1. Re: Load Data from External .txt file
          compubrook Level 1
          Can someone please take a look at this? It is taken from the example in the help file.
          • 2. Re: Load Data from External .txt file
            BLXWebMaster Level 1
            If you simply need to read a text file, I would go about it like this....
            <mx:Application
            xmlns:mx=" http://www.adobe.com/2006/mxml"
            layout="absolute"
            initialize="myService.send()">
            <mx:Script>
            <![CDATA[
            import mx.rpc.events.ResultEvent;
            [Bindable]
            private var myData:String;
            private function resultHandler(event:ResultEvent):void {
            myData = myService.lastResult.toString();
            </mx:Script>
            <mx:HTTPService id="myService" url="test.txt" result="resultHandler(event)"/>
            <mx:Text id="something" text="{myData}"/>
            </mx:Application>
            Allen
            • 3. Load Data from External .txt file
              compubrook Level 1
              Thanks for your help!
              What I'm trying to do is be able to read in the two addresses for 2 HTTPServices.
              the text file would be:
              pSrv=http://localhost/gbkiosk/getdata.php?length=day&pSrv2=http://localhost/gbkiosk/getdat a.php?length=week
              then my serrvice calls would loo like this
              <mx:HTTPService id="pSrv"
              url={pSrv}
              <mx:HTTPService id="pSrv2"
              url={pSrv2}
              result="chartComplete(event)"
              • 4. Re: Load Data from External .txt file
                Can you use an XML file instead of a text file. I think you are going to run into a lot more work if you are trying to parse a text file and extract the information you want the way you want it. This one is fine beacuse it contains only 1 "&" which you can use as a delimiter. Much easier if the file was a XML file.
                Here is a quick working example using split.
                <mx:Application
                layout="absolute"
                <mx:Script>
                <![CDATA[
                [Bindable]
                [Bindable]
                private var myArray:Array;
                myArray = myData.split('&');
                </mx:Script>
                <mx:Text id="something" text="{myArray[0]}"/>
                <mx:Text id="something1" text="{myArray[1]}" y="26"/>
                </mx:Application>
