• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Connection verification failed for data source
New Here ,
Jul 08, 2014 Jul 08, 2014
Hi, I'm trying to connect to a MS SQL2000 and a MYSQL server with CF11.
System WIN7, Apache32, bit CF11 32 bit, the error message is.
Connection verification failed for data source: picos
java.sql.SQLException: [Macromedia] [SequeLink JDBC driver] [ODBC socket] internal error: the data source name not found and no default driver specified
The root cause what that: java.sql.SQLException: [Macromedia] [SequeLink JDBC driver] [ODBC socket] internal error: the data source name not found and no default driver specified
What can I do? Thank you for an answer.
friendly greetings
Jochen Vetter
TOPICS
Database access
Views
1.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide ,
Why are you using ODBC to connect to MS SQL Server or MySQL?  Use the provided JDBC drivers - they are faster and more reliable than ODBC.  Consider ODBC a database connection method "of last resort" (i.e., only when a JDBC driver isn't available).
-Carl V.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 11, 2014 Jul 11, 2014
LATEST
You certainly filled in incorrect values in the form on the datasource page of the Coldfusion Admnistrator. If the problem persists, make a printscreen of the values you fill in the form. We would be glad to discuss it.
Votes
Translate
Translate
Report
Report
Resources
Documentation
