7 Replies Latest reply: Jul 16, 2014 11:45 PM by Zhihong Chen RSS
    Extension caches iframe content
    JeffW. Community Member
      hi,
      I'm using an iframe in my HTML5 extension to load an external page,
      which includes javascript files.
      When these are changed on the server and I re-open the panel or even re-start Premiere, the old js
      is being cached.
      I believe the exact same problem was describe here
      Photoshop HTML5 extension caches iframe all the time
      but no answer,
      I tried some common tricks like adding a timestamp to the url
      or clearing the iframe's src at startup, but no luck.
      Is there a way to clear the cache of an extension?
      thanks,
      Jeff.
        • 1. Re: Extension caches iframe content
          Hallgrimur Bjornsson Adobe Employee
          You should be able to disable the cache entirely - per extension using this Chromium parameter: -disable-application-cache
          In your manifest file, add:
          </CEFCommandLine
          Best regards,
          Hallgrimur
          Hallgrimur Th. Bjornsson | CCE Product Manager - Enterprise  Dashboard - Extensibility| Adobe | Tel: +44 (0) 1314582787
          • 2. Re: Extension caches iframe content
            weiguo@adobe.com Adobe Employee
            Jeff,
            What would happen if you load your HTML (with iframe) in Chrome browser? Does Chrome cache iframe content?
            • 3. Re: Extension caches iframe content
              Thanks, Hallgrimur's code was cutt of, see the attachment on what to add and where I added it: inside the DispatchInfo tag.
              Also, I only have this problem
              with our third party payment partner, not when I did a test
              with another website. So we need to look into that on our side.
              • 4. Re: Extension caches iframe content
                sorry, my previous post was based on testing it incorrectly.
                Adding the --disable-application-cache does NOT work for me in the extension.
                Files (i only tested js files, but with loading different html pages/urls) are still being cached. I see the old file when I look it up in the Resources of the cef remote debugger.
                When I click the file, which takes me to the real url's source, I see the updated file.
                I also tested loading the same page in an iframe in the browser. There's no problem there,
                it updates fine.
                • 5. Re: Extension caches iframe content
                  Zhihong Chen Adobe Employee
                  Hi Jeff,
                  Could you please try adding “nodejs-disabled="true"” into your iframe label and check this issue again (Just a try)?
                  CEP integrates Node.js and it conflicts with some iframe function. We can disable Node.js in iframe to fix this kind of error:
                  Old Code Example:    <iframe id="testID"></iframe>
                  New code Example:   <iframe id="testID" nodejs-disabled="true"></iframe>
                  • 6. Re: Extension caches iframe content
                    Thanks Zhihong,
                    I already tried that, and I've just tried it again,
                    but js file is still being cached,
                    even after re-opening the panel and also restarting Premiere.
                    • 7. Re: Extension caches iframe content
                      Hi Jeff,
                      Thank you for reporting this. I made a simple test extension (shared here), set up a local server to try this, but failed to reproduce this error. In file CEP_HTML_Test_Extension-5.0\html\HTMLFeatures.html, there is a <iframe> label that points to web page index.html (in folder Server_pages). Index.html contains a JavaScript file myscript.js which outputs current time to front page.
                      Every time I reload the HTML Test extension, current time could be updated in the “HTML Features” page. My platform is Windows7 64-bit.
                      Can these test extension and server pages simulate your issue? If so, could you please try it on your local machine and check whether we see the same result or not? Thanks!
                      PS. CEP cache path is:
                      • Windows: C:\Users\USERNAME\AppData\Local\Temp\cep_cache\
                      • Mac: /Users/USERNAME/Library/Logs/CSXS/cep_cache
                      There is no CEP API to clear cache now.
