1 Reply Latest reply on May 5, 2007 12:06 PM by dr_ross
    combox mystery
    Optikalefx Level 1
      I have some combo boxes that i have attached to the stage with attachMovie. I used a for loop to attach many combo boxes. after you click a button to submit the data in the boxes it takes u to another frame, but the combo boxes are still on the stage even 10 frames later, even with blank keyframes right after the frame that holds the combo boxes. how do i get rid of these *******.
        • 1. Re: combox mystery
          dr_ross Level 1
          once you've attached something to the stage programmatically its there until you remove it with code, or remove the movieclip they've been loaded into.
          You can either call removeMovieClip() on them or load them into a blank movieclip on the stage and then have that removed on the frame you need.
