• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Query Of Query of ordered result set error in CFSCRIPT in CF10
Explorer ,
Jul 08, 2014 Jul 08, 2014
I have come across a very interesting error when doing a query of a query inside a CFSCRIPT tag...
I get a result set back from a SQL Server stored procedure.  It is a list of metric names (METRIC_ID) and the actual metric measurements.
I need to pull the METRIC_ID from this result set to do a JOIN on another query that has display and other formatting attributes for display in a web page.
The following code executes with no errors when the query is unordered:
var displayDataQuery = new Query();
displayDataQuery.setName("joinedQuery");
displayDataQuery.setDBType("query");
displayDataQuery.setAttributes(qry1 = fullMetricsListQuery);
displayDataQuery.setAttributes(qry2 = arguments.cubeData);
displayDataQuery.setSQL("SELECT METRIC_ID FROM qry2");
var tempResultSet = displayDataQuery.execute();
var cubeMetricIDList = tempResultSet.getResult();
When I take the same exact query results from the same stored procedure, but it's ordered by an ORDER BY clause, this statement;
throws the following error - "The value '' cannot be converted to a number."   That's 2 single quotes, signifying an empty string between "value" and "cannot."
Wait, what???  I just want a list of metric names, varchars.  Why is there a conversion error...?
The error ultimately points back to ColdFusion10\cfusion\CustomTags\com\adobe\coldfusion\base.cfc, line 445.
OK, this is where this takes an interesting turn...
Starting at line 444 in base.cfc, Line 445 bolded in red:
<cfif sqlType neq "" and arraylen(sqlParams) gt 0>
    <cfloop index="i" from="2" to="#ArrayLen(sqlArray)#">
          <cfif (i-1) lte arraylen(sqlParams)>
               <cfqueryparam attributeCollection="#sqlParams[i-1]#"/>
          </cfif>
          #getPreserveSingleQuotes(sqlArray)#
     </cfloop>
</cfif>
So if I understand this correctly, when I have an unordered query, this code in base.cfc reads the SQL set in displayDataQuery.setSQL("SELECT METRIC_ID FROM qry2"), but doesn't when the query is ordered by METRIC_ID...?
Ah, wait...  the CFDUMP when using an ordered data set says something else...
query
RESULTSET
CACHEDfalse
EXECUTIONTIME4
SQLSELECT * FROM qry1 ORDER BY METRIC_ID, LOCATION
I'm pretty much stumped why the same data in unordered set works while in an ordered set causes this error.
Any and all helpful suggestions or clues will be greatly appreciated!!!
Views
522
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Jul 10, 2014 Jul 10, 2014
Do you mean the error occurred without the order-by clause?
Since the error doesn't occur with an unordered data set, I'm a little confused why you would ask this...?
I followed your suggestion:
Run the same code, but then use the cfquery tag instead of cfscript. Does the error still occur?
My assumption was your suggestion was to test against an ordered data set as that's what was causing the original error.
Unfortunately the error occurs in both tag-based and script-based scenarios.
This mak
Votes
Translate
Translate
Community Expert ,
Jul 09, 2014 Jul 09, 2014
The explanation got a bit confusing towards the end. You first said the query that caused the issue is "SELECT METRIC_ID FROM qry2 ORDER BY METRIC_ID". Later on you mention the query "SELECT * FROM qry1 ORDER BY METRIC_ID, LOCATION". Which one is it?
Votes
Translate
Translate
Report
Report
Explorer ,
Oops, you caught a defect in my post!
The SQL should be "SELECT METRIC_ID FROM qry2 ORDER BY METRIC_ID" in both places.  I copied/pasted the wrong CFDUMP output.
The entire CFC is in a CFSCRIPT tag, but I'll do a little rework and see if your suggestion works.
Votes
Translate
Translate
Report
Report
Explorer ,
This code threw the exact same error at the beginning of the CFQUERY:
<cfcomponent>
  <cffunction name="getDisplayDataValueList"
  returntype="any"
         access="public"
  displayname="getDisplayDataValueList"
  description="I return a value list of the metric ids to be displayed">
  <cfargument name="cubeData" type="query" required="true">
  <cfquery name="cubeMetricIDList" dbtype="query" >
  SELECT METRIC_ID
   FROM arguments.cubeData
  </cfquery>
  <cfreturn ValueList(cubeMetricIDList.metric_id)>
  </cffunction>
</cfcomponent>
Votes
Translate
Translate
Report
Report
Community Expert ,
  SELECT METRIC_ID
  </cfquery>
Votes
Translate
Translate
Report
Report
Explorer ,
This makes absolutely no sense why this occurs.  The order of a data set should have no bearing on a Query of a Query on a column defined as a varchar.
If there are null values in the other columns defined as some type of numeric, big deal, the code in question isn't trying to evaluate those columns.  Even more interesting is why unordered vs. ordered makes a difference.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
My suggestion was indeed to test against an ordered data set, as that is what was causing the original error. However, the query you apparently used - which I quoted - is unordered.
Votes
Translate
Translate
Report
Report
Resources
Documentation
