6 Replies Latest reply on Jul 10, 2014 9:36 AM by A.T. Romano
    problème de transcodage
    6nemas
      je suis désolée mais je ne parle pas anglais.
      j'ai acheté un ordinateur plus puissant (le ASUS R900V) et j'y ai mais adobe premiere element 12.
      j'ai déjà réalisé 2 montage avec, et le dernier, je n'arrive pas à le graver sur DVD. Il code 1 puis 2 puis 3 puis 4 et à la fin au bout de 16% il marque "erreur de transcodage" et il s'arrête.
      Que dois-je faire ?
      merci d'avance
      Lau
        • 1. Re: problème de transcodage
          A.T. Romano Level 7
          LAU
          What computer operating system is your Premiere Elements 12 running on?
          I am assuming that you are doing a burn to disc for DVD-VIDEO standard or widescreen on DVD disc and not AVCHD on DVD.
          The typical sequence is
          Encoding Menus 1 of 2, 2 of 2
          Encoding Media
          Compiling Media
          Burn
          At which stage do you get the Transcoding Error?
          It is more than likely that you have a flaw in the TImeline...a gap or fragments.
          Go to the Expert workspace and expand (to the maximum) the Timeline content with the -+ slider above the Timeline.
          Then inspect the tracks for irregularities -  very thin black vertical lines scattered about the tracks.
          Look for the placement of transitions and gaps, audio or otherwise.
          Do you have menu markers on the Timeline? If so, look at their placement to make sure that there is enough room between them.
          And, never have a stop marker at the end of the last item on the Timeline. Your error message does not fit the profile for the later,
          but I mention that stop marker problem nonetheless.
          Also, when you are in the burn dialog, you have your disc in the burner tray, and you are just about to hit the Burn button of the
          burn dialog ---what does the Quality Area of the Burn dialog show for Space Required and Bitrate?
          Please also review the Adobe document on troubleshooting burn to issues in order to determine if there is anything in it
          that might help you.
          Troubleshoot system errors, freezes | Burning DVDs, blu-ray discs | Premiere Elements | Windows
          We will be watching for your follow up.
          Thank you.
          ATR
          • 2. Re: problème de transcodage
            6nemas Level 1
            Bonjour
            Je travaille sur Windows 8.
            Effectivement, je grave pour la norme DVD vidéo.
            Les menus 1 de 4, 2 de 4, 3 de4 et 4 de 4 se déroulent normalement. C’est juste après, au moment de la compilant de gravure que je n’atteints que 16%.
            Je vais vérifier sur le montage s’il y aurait des imperfections entre deux images, au niveau des transitions…
            Je vous tiens au courant.
            Merci et à très vite
            Lau
            De : A.T. Romano
            Envoyé : mardi 8 juillet 2014 20:37
            À : laurence brengues
            Objet :  problème de transcodage
            created by A.T. Romano <https://forums.adobe.com/people/A.T.+Romano>  in Premiere Elements - View the full discussion <https://forums.adobe.com/message/6533229#6533229>
            • 3. Re: problème de transcodage
              6nemas Level 1
              Je crois que j’ai trouvé mon erreur ; les marques de début et de fin du montage n’étaient pas bien placées. La première n’était pas au début du montage. Je viens de relancer la gravure.
              Je vous tiens au courant dès que le travail est terminé.
              Bien sincèrement
              Lau
              De : A.T. Romano
              • 4. Re: problème de transcodage
                A.T. Romano Level 7
                6nemas
                Thank you for the update.
                Sounds like very great news. We will be watching for the outcome.
                ATR
                • 5. Re: problème de transcodage
                  6nemas Level 1
                  désolée, mais la gravure s'est arretée au meme endroit.
                  Je vais de nouveau essayé de vérifier tous vos conseils, et je vous tiens au courant.
                  seulement, je suis maintenant sur mon lieu de vacances et je n'ai pas internet, donc mon message risque d'être un peu éloigné.
                  merci pour tout
                  Lau
                  Message du 08/07/14 22:48
                  De : "A.T. Romano"
                  A : "laurence brengues"
                  Copie à :
                  created by A.T. Romano in Premiere Elements - View the full discussion
                  6nemas
                  ATR
                  Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at https://forums.adobe.com/message/6533776#6533776
                  Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
                  To unsubscribe from this thread, please visit the message page at . In the Actions box on the right, click the Stop Email Notifications link.
                  Start a new discussion in Premiere Elements by email or at Adobe Community
                  For more information about maintaining your forum email notifications please go to http://forums.adobe.com/thread/416458?tstart=0.
                  • 6. Re: problème de transcodage
                    A.T. Romano Level 7
                    6nemas
                    Sorry that the news was not better, but do not give up.
                    Please let us know the outcome after you go back to your expanded Timeline content and inspect it again for irregularities
                    I understand that you are now on holiday. We will be looking forward to your results at the end of your holiday and
                    when you have time.
                    Safe travel and wonderful holiday.
                    ATR
