5 Replies Latest reply on Jul 10, 2014 11:36 AM by Jennifer Hearing
    Apply table style based on cell content
    Jennifer Hearing
      I am using InDesign 5 and am on a Mac, OS 10.8.5.
      Does anyone know how to apply a table style based on text contents found in a cell in javascript?
      I need to search the document and change every table style to "verbatim orange LONG" if the text "HS:" appear in the header row.
      I've been playing with the scripts found in the following 3 threads, but can't get it to apply a table style.
      Thanks!
      Apply Table Cell Style Based on Text Search and How to apply a table cell style based on grep search? and Re: Find PStyle and apply Cell Style in Table
        • 1. Re: Apply table style based on cell content
          Kai Rübsamen Level 4
          I’m not sure, if this will work in CS5, since I have here only CS6 up, but try this one:
          var curDoc = app.activeDocument;
          var allTables = curDoc.stories.everyItem().tables.everyItem();
          app.findTextPreferences = app.changeTextPreferences = null;
          app.findTextPreferences.findWhat = "HS:";
          var allFounds = allTables.findText();
          for ( var i = 0; i < allFounds.length; i++ ) {
              var curFound = allFounds[i];
              var curFoundParent = curFound[0].parent;
              if ( curFoundParent.parentRow.rowType == RowTypes.headerRow ) {
                  curFoundParent.parent.appliedTableStyle = curDoc.tableStyles.itemByName( "verbatim orange LONG" );
          –Kai
          • 2. Re: Apply table style based on cell content
            Jennifer Hearing Level 1
            Kai,
            Thank you for your reply! I tried the script and it "almost" works.
            I get an error message "Error 21: Undefined is not an object." Then it says the error is on line 11:   var curFoundParent = curFound[0].parent;
            It does change the first table in the document that has "HS:", but none of the other tables with "HS:". Not sure what the snag is.
            • 3. Re: Apply table style based on cell content
              Hm, that means, that the syntax in this line work not in every case. Can you sent me a testfile with the right an one wrong table via link to the forum or private mail?
              I will try to solve the problem.
              • 4. Re: Re: Apply table style based on cell content
                Here are the corrected lines:
                    if ( curFound.length == 1 ) {
                • 5. Re: Re: Apply table style based on cell content
                  Yes, that works great! Thanks!
