I only want to print a page if two conditions are met. On each section I am using the following Print When Condition:
DateFormat(query.asofdate, "mm/dd/yyyy") NEQ DateFormat(calc.AmtDate, "mm/dd/yyyy") AND LSNumberFormat((query.bal + calc.anticipated), "_.__") LTE LSNumberFormat(25.00, "_.__").
The date check works great by itself and the amount check works great by itself but I can't get them to work together. Any ideas?
I am using CF10.
If the field types are explicit, then you don't need to format them as strings before comparing them.
What happens if you try the following expression?:
( (query.asofdate NEQ calc.AmtDate) AND (query.bal + calc.anticipated LTE 25.00) )
That fixed the problem Thanks!
Is there anyway I can apply this to the whole page and not have to add it to every sections 'Print When Condition'?
One way would be to exclude records that meet those conditions. That way you would not need to take them into account in your report.
