6 Replies Latest reply on Jul 23, 2014 11:36 AM by Alteva
    I have a consistent and reproducible crash - InDesign CC 2014 - Mac OS - Mavericks
    Iiodaoa
      Hello all.  I installed the 30-d trial of Indesign CC 2014.  I have a reproducible crash that I can't seem to get away from.
      It happens when I create a text box, or just select the type tool, create the box, and start typing.  This all works fine.  The crash occurs if I click in the box and try to move it.  It crashes every single time, without fail.  It doesn't happen if I use the arrows to move the box.  Only when I click in the box and try to move it with the mouse.  It's maddening!
      I've deleted all preferences, as well as the the InDesign caches, etc in ~Library (per another recommendation) which didn't help.
      Here is the crash log....Please help!
      Process:         Adobe InDesign CC 2014 [50848]
      Path:            /Applications/Adobe InDesign CC 2014/Adobe InDesign CC 2014.app/Contents/MacOS/Adobe InDesign CC 2014
      Identifier:      com.adobe.InDesign
      Version:         10.0.0.70 (10000)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [162]
      Responsible:     Adobe InDesign CC 2014 [50848]
      User ID:         501
      Date/Time:       2014-07-10 07:29:51.030 -0500
      OS Version:      Mac OS X 10.9.3 (13D65)
      Report Version:  11
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: KERN_INVALID_ADDRESS at 0x00007fa80001d023
      VM Regions Near 0x7fa80001d023:
          MALLOC_NANO            0000608001400000-0000608003800000 [ 36.0M] rw-/rwx SM=PRV
          MALLOC_TINY            00007fa8f9c00000-00007fa8fa000000 [ 4096K] rw-/rwx SM=PRV
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   com.apple.CoreFoundation       0x00007fff8afe5a80 __CFPasteboardLockTry + 160
      1   com.apple.CoreFoundation       0x00007fff8b060cd6 CFPasteboardBeginGeneration + 70
      2   com.apple.HIServices           0x00007fff8b17aaef PasteboardClear + 33
      3   com.adobe.InDesign.Application UI 0x000000011072a0ee 0x1105e9000 + 1315054
      4   com.adobe.InDesign.Application UI 0x00000001106689db 0x1105e9000 + 522715
      5   com.adobe.InDesign.Layout UI   0x0000000113525806 0x113429000 + 1034246
      6   com.adobe.InDesign.Layout UI   0x000000011344c00a 0x113429000 + 143370
      7   com.adobe.InDesign.Layout UI   0x0000000113438f61 0x113429000 + 65377
      8   com.adobe.InDesign.Layout UI   0x0000000113438bfc 0x113429000 + 64508
      9   DV_WidgetBinLib.dylib         0x00000001033abedb DVEventHandler::DVPointerEvent(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool&) + 315
      10  DV_WidgetBinLib.dylib         0x0000000103396303 DVHostedWidgetView::PrivateImpl::PointerEventCallback(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool&) + 83
      11  DV_WidgetBinLib.dylib         0x000000010339aed3 0x103389000 + 73427
      12  com.adobe.dvaui.framework     0x0000000103fc3792 dvaui::ui::UI_Node::UI_DispatchCustomPointerEventToNode(dvaui::ui::UI_Node*, boost::intrusive_ptr<dvaui::ui::UI_Node>, dvaui::ui::PointerEvent const&, bool&) + 146
      13  com.adobe.dvaui.framework     0x0000000103fc347a dvaui::ui::UI_Node::UI_DispatchPointerEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&) + 170
      14  com.adobe.dvaui.framework     0x0000000103fc2d60 dvaui::ui::UI_Node::DispatchPointerEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 128
      15  com.adobe.dvaui.framework     0x0000000103fcac3a std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 154
      16  com.adobe.dvaui.framework     0x0000000103fcac22 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 130
      17  com.adobe.dvaui.framework     0x0000000103fcac22 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 130
      18  com.adobe.dvaui.framework     0x0000000103fcac22 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 130
      19  com.adobe.dvaui.framework     0x0000000103fcac22 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeafT<dvaui::ui::UI_Node::DispatchPoint erEvent>(dvaui::ui::UI_Node::DispatchPointerEvent&, dvacore::geom::PointT<float> const&, bool) + 130
      20  com.adobe.dvaui.framework     0x0000000103fc1f21 dvaui::ui::UI_Node::UI_DispatchPointerEventTowardsLeaf(dvaui::ui::PointerEvent const&, bool) + 65
      21  com.adobe.dvaui.framework     0x0000000103fc15e2 dvaui::ui::UI_Node::UI_DispatchPointerEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::PointerEvent const&, bool) + 194
      22  com.adobe.dvaui.framework     0x0000000103fc1472 dvaui::ui::UI_Node::UI_DispatchPointerEvent(dvaui::ui::PointerEvent const&, bool) + 66
      23  com.adobe.dvaui.framework     0x000000010403f560 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 608
      24  com.adobe.dvaui.framework     0x000000010403f0de dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 606
      25  com.adobe.dvaui.framework     0x000000010403d489 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 121
      26  com.adobe.dvaui.framework     0x000000010403d3e6 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 22
      27  com.adobe.dvaui.framework     0x000000010403eb69 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 57
      28  com.adobe.dvacore.framework   0x00000001039ee8dc int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      29  com.adobe.InDesign.Application UI 0x000000011071ed12 0x1105e9000 + 1269010
      30  com.adobe.dvacore.framework   0x00000001039eea28 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 136
      31  com.adobe.dvacore.framework   0x00000001039efdc5 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 165
      32  com.adobe.dvaui.framework     0x00000001040499da dvaui::ui::OS_NodeTimerData::RemoveTimer() + 27242
      33  com.apple.AppKit               0x00007fff81dfaa58 -[NSWindow sendEvent:] + 11296
      34  com.adobe.owl                 0x00000001037ea764 0x1037b3000 + 227172
      35  com.apple.AppKit               0x00007fff81d995d4 -[NSApplication sendEvent:] + 2021
      36  com.adobe.dvaui.framework     0x000000010404334b dvaui::ui::OS_NodeTimerData::RemoveTimer() + 987
      37  com.adobe.exo.framework       0x0000000105bc4c25 exo::app::OS_AppBase::SetResetMenuShortcutsOnClose(bool) + 837
      38  DV_WidgetBinLib.dylib         0x0000000103418295 0x103389000 + 586389
      39  com.adobe.InDesign.Application UI 0x00000001107251df 0x1105e9000 + 1294815
      40  com.apple.AppKit               0x00007fff81be9a19 -[NSApplication run] + 646
      41  com.adobe.exo.framework       0x0000000105bc4648 exo::app::OS_AppBase::RunEventLoop() + 56
      42  com.adobe.InDesign.AppFramework 0x00000001104dac03 0x1103c2000 + 1149955
      43  com.adobe.InDesign.AppFramework 0x00000001104d9d0c 0x1103c2000 + 1146124
      44  com.adobe.InDesign             0x000000010334178f main + 303
      45  com.adobe.InDesign             0x00000001033415f4 start + 52
      Message was edited by: Peter Spier
