2 Replies Latest reply: Nov 3, 2014 12:57 AM by t6mass RSS
    Create reusable CSS with class definitions?
    nicofnot Community Member
      The exported project contains so many redundant styles it isn't logical for me to want to use this software as-is. I want to generate cleaner CSS with the HTML generated from Adobe Edge Reflow. Being able to define a class style would be amazingly helpful. Can we get a style definition panel that allows us to define a class, then simply assign the class to elements so that the amount of redundant CSS is significantly reduced.
      As it is, everything is based on CSS ID definitions except for those provided in the HTML5BP 'boilerplate.css' stylesheet (mostly seeing clearfix and image classes used on generated HTML elements).
      Thank you for your consideration.
