1. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
Arnis Gubins Jul 10, 2014 7:50 PM (in response to LaurenASML)Did you uninstall the RH11 trial before installing the TCS suite? The standalone versions do not have the "secret sauce" components that integrate the FM, RH and Captivate modules.
2. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Jul 11, 2014 2:05 PM (in response to Arnis Gubins)Robohelp 11 trial was uninstalled and I cleaned out the registry for Robohelp 11 items as best I could. The weird thing is the link is there and i can update when I first open the project and then the 2nd time I open the project, I can no longer do these things.
3. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
mattrsullivan Aug 13, 2014 10:50 AM (in response to LaurenASML)First my client, then I saw the exact same thing.
One day the project worked perfectly, then the next day the linking options were all unavailable. It's as if Rh decided it was no longer associating with Fm.
Oddly, another client team member was unaffected.
I'm trying to track down the issue. Did you resolve the linking problem?
4. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
mattrsullivan Aug 13, 2014 10:55 AM (in response to mattrsullivan)I reinstalled from the TCS5.1 installer and all is well...
5. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Aug 13, 2014 1:50 PM (in response to mattrsullivan)After updating to 5.1, the Link menu command still shows FrameMaker grayed out as if it does not exist.
6. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
Jeff_Coatsworth Aug 14, 2014 6:02 AM (in response to LaurenASML)Does it have a RoboHelp menu item over in FM? There used to be a dll that TCS had that the standalone versions didn’t that sometimes needed to be added to your maker.ini to kick the linkage part to work, but I can’t remember what it was called or where it was hiding.
7. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Aug 14, 2014 11:54 AM (in response to Jeff_Coatsworth)I do not see a RoboHelp menu in FM 12.
In my FM 11 maker.ini, in the API Clients area, I see RoboHelpPublish=Standard, Client for publishing help formats, fminit\RoboHelpPublish.dll, all
8. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
Jeff_Coatsworth Aug 14, 2014 11:58 AM (in response to LaurenASML)Yes, I saw that too in my FM10 & 11 installs – it wasn’t that one though – that does the direct publishing bit in FM. I need to check an old XP machine with TCS2 or 3.5 on it.
9. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Aug 14, 2014 12:05 PM (in response to Jeff_Coatsworth)Were you thinking of:
RH4FMver9=Standard,RH4FMver9,C:\Program Files\Adobe\Adobe Technical
Communication Suite 2\Adobe RoboHelp
8\RoboHTML\RHFrameMakerServer9.dll,all
10. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
Jeff_Coatsworth Aug 14, 2014 12:14 PM (in response to LaurenASML)Maybe – was that in the Program Files maker.ini or the User Profile one? I seem to remember having to add it to the User one to repair one of my upgrades one time.
11. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Aug 14, 2014 12:26 PM (in response to Jeff_Coatsworth)the maker.ini in USer/AppData/Roaming/FrameMaker/9 folder under APIClients
12. Re: TCS 5 RoboHelp and FrameMaker links work and then stop
LaurenASML Aug 14, 2014 12:27 PM (in response to LaurenASML)But none of the later versions of FM that i have use something in the User maker.ini so it may not be a valid item anymore.
