9 Replies Latest reply on Jul 15, 2014 1:53 AM by joel_pau
    Find and replace html text
    Xoco Level 3
      I need replace some text in several descendants elements of rXefsList div for to translate my website.
      I try with jQuery find() Method but this doesn't works for html text:
      sym.$("rXefsList").find("JULIOL").html("JULY");
      or
      sym.$("rXefsList").find("div").map( function(){
          if (this.html()=="JULIOL"){ this.html("JULY"); }});
      If I view source code, this is the content line:
      <div id="Stage_sb1309m" class="edgeLoad-EDGE-67786006">JULIOL</div>
      What method I need to use for this purpose?
      Thanks.
        • 1. Re: Find and replace html text
          Xoco Level 3
          Viewing the last example of .find() | jQuery API Documentation, I see that the correct syntax is:
          sym.$("rXefsList").find(":contains('JULIOL')")
          but only works if I change a css property
            .css({
             "font-style": "italic",
             "font-weight": "bolder"
          not if I change text with jQuery html() Method or jQuery text() Method
          sym.$("rXefsList").find(":contains('JULIOL')").html("JULY");
          • 2. Re: Find and replace html text
            heathrowe Most Valuable Participant
            Try the replace method JavaScript String replace() Method
            sym.$("rXefsList").html(sym.$("rXefsList").html().replace('JULIOL', 'JULY'));
            hth
            Darrell
            • 3. Re: Find and replace html text
              Xoco Level 3
              Thanks, but I need change text of severals childs of rXefsList div, not html text of rXefsList directly, are elements (inserted with text tool) descendants of rXefsList.
              Like tv2007m div:
              • 4. Re: Find and replace html text
                Then you can utilize the same method on those elements, individually
                sym.$("tv2007m").html(sym.$("tv2007m").html().replace('xxxx', 'yyyyy'));
                sym.$("tv2007d").html(sym.$("tv2007d").html().replace('wwww', 'zzzzz'));
                repeat the above for other elements.
                Darrell
                • 5. Re: Re: Find and replace html text
                  joel_pau Level 5
                  So, i go on.
                  You have to create a collection then browse it to change your word.
                  Here are 3 options:
                  Option 1 (for teaching proposes):
                  var myCollection = sym.$("Stage").find(':contains("oneWord")');
                  $.each(myCollection, function(){
                  $(this).html( $(this).html().replace("oneWord", "anotherWord") );
                  Option 2 (for teaching purposes):
                  myCollection.each( function(){
                  Option 3:
                  sym.$("Stage").find(':contains("oneWord")').each( function(){ $(this).html( $(this).html().replace("oneWord", "anotherWord") ); } );
                  • 6. Re: Find and replace html text
                    Xoco Level 3
                    If I send myCollection to console.log:
                    Parents are included by innerHTML property, and if I try this:
                    $("div#Stage_tv2007m").html( $("div#Stage_tv2007m").html().replace("JULIOL", "JULY") );
                    Works fine, but not work when I try
                    $(this).html( $(this).html().replace("JULIOL", "JULY") );
                    Because I can not use "this" (only in this project) and I do not know why (nothing happens): Use of "this"
                    Example, in mouseenter event of a img, If I try:
                    this.css("bottom","+=2px");
                    nothing happens, I must to use:
                    sym.$('facebook').css("bottom","+=2px");
                    I have reviewed that has no element or name variable with this name ("this"), but it is not.
                    PD: I have also looked HTML DOM textContent Property but nothing.
                    • 7. Re: Find and replace html text
                      joel_pau Level 5
                      Before writing my previous post (#5), i've tested. Here are pics: my code panel and my elements on stage.
                      I will add this demo file.
                      • 8. Re: Find and replace html text
                        Xoco Level 3
                        Yes, your example work fine, but in a new project, with my current project I have problems using this. or $(this). method in code. I've open a discussion about it Re: Use of "this"
                        Thank you for your correct answer.
                        • 9. Re: Find and replace html text
                          joel_pau Level 5
                          As it is an event, User Interface provides you : e.target.
                          For instance: $(e.target). hide(); or sym.$(e.target).hide(). The current element (button) will be hidden.
                          console.log( e.type, e.target ) returns the event and the target.
                          console.log( e.target.id ) returns the id of the element targeted.
