0 Replies Latest reply on Jul 12, 2014 1:50 AM by Marvinhowru
    Color Matrix Handling for M-JPEG Codec
    Marvinhowru
      Hi folks, I have some 4K video file from Canon EOS-1D C, which were encoded using Motion JPEG codec, please see the following detail:
      Video
      Format                                   : JPEG
      Codec ID                                 : jpeg
      Duration                                 : 3s 800ms
      Bit rate mode                            : Variable
      Bit rate                                 : 518 Mbps
      Width                                    : 4096 pixels
      Height                                   : 2160 pixels
      Display aspect ratio                     : 1.896
      Frame rate mode                          : Constant
      Frame rate                               : 25.000 fps
      Color space                              : YUV
      Chroma subsampling                       : 4:2:2
      Bit depth                                : 8 bits
      Compression mode                         : Lossy
      Bits/(Pixel*Frame)                       : 2.343
      Stream size                              : 235 MiB (100%)
      Title                                    : Core Media Video
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.601
      The problem is that After Effects CC 2014 misinterpret the video file as BT.709 when Color Management is turned on, and I'm unable to manually assign BT.601 profile as the option is grayed out.
      It's odd that color primaries and transfer characteristics are BT.709 but matrix coefficients remain BT.601, is there any way to correctly interpret this footage and mix with other files that are standard BT.709 matrix?
      Thanks a lot
