4 Replies Latest reply on Jul 12, 2014 9:01 AM by subone
    After Effects error crash in progress..
    subone
      Hello,
      I am using After Effects CS6 64 bit, and almost everytime when I navigate inside the program ( Change scale of a layer,adjust masks...),
      After Effects crashes and I get this error:
      After Effects error: Crash in progress. Last logged message was: <748>
      <DynamicLink> <5> C:\Program Files\Adobe\Adobe Premiere Pro CS6
      The weird thing is that I don't have Premiere Pro CS6 installed.
      How can I fix this ?
      Thanks.
        • 1. Re: After Effects error crash in progress..
          1. Make sure that CS six is fully up-to-date
          2. Answer this question: has CS6 ever worked on your system?
          3. If this is a new behavior, what changed?
          4. Tell us what operating systems you are using.
          With a little bit more information we might be able to help a little bit more.
          • 2. Re: After Effects error crash in progress..
            AE uses specific components it has in common with Premiere, hence the message. Either way, your post is mostly useless. You have not provided any proper technical details like system info, comp settings, footage used and its interpretation, pref settings and so on.
            Mylenium
            • 3. Re: After Effects error crash in progress..
              subone Level 1
              1. I updated it to latest version (11.0.4) but I am still facing this problem.
              2. Yes it worked.
              3. AE used to crash when I used to use some plugins (like Zaxwerks 3d flag).
              But yes this error is appearing recently.
              4. Windows 7 Ultimate 64 bit Service Pack 1
              • 4. Re: Re: After Effects error crash in progress..
                subone Level 1
                Mylenium
                System info:
                Comp Settings:
                Preference Settings:
                Media & Disk Cache
                Memory & Multiprocessing
                Footages used: Images and PSD files.
