3 Replies Latest reply on Jul 16, 2014 3:21 PM by dajupe
    Responsive Scaling still not working correctly?
    bobba1 Level 1
      Hello, I am using the latest version (2014) of Edge Animate, trying to create a .oam file that I place into Dreamweaver (2014) that is supposed to scale based on the size of the browser. I am checking the box that says 'responsive scaling' when working in Edge animate. I'm noticing this feature still seems to not be working correctly. I can get the width to scale properly by specifying 'width="100%"' in the div of the EDGE object that is placed inside of Dreamweaver when I add the .oam file EDGE animation as media (From the Dreamweaver INSERT=>MEDIA=>EDGE ANIMATION COMPOSITION). When I do this and open up the page in a browser, the width scales fine, but the height does not. What happens is this - as I scale down the size of the browser, it appears to keep the same height (probably in pixels) always, no matter the size of the browser window. So, when the browser is large, the space at the bottom of the EDGE composition is small, and the next divs below the EDGE composition place reasonably well. As I make the browser window smaller - say the size of a tablet, the bottom of the EDGE composition appears to push down the divs below it, creating what looks like a padding or a margin that is significant. As I shrink the browser down even further - say to the size of a smart phone, the gap between the bottom of the EDGE composition and the next div below it is huge - probably about 75% of the entire length of the page. I believe this was a known issue in the last version of EDGE ANIMATE ( Create an Edge Animation that fluidly scales width/height inside a website )  and that some workarounds may have been developed, but to me - if I am not missing something simple - is a major flaw in this program. I thought that one of the benefits of EDGE ANIMATE was supposed to be that it was a good tool for minimizing the work of writing the code manually in javascript and css, but in this very simple task - just creating an animation that scales to browser size and dropping it into the website as a .oam file - isn't working. So I can't really use what the tool generates. My only other choice is to spend days on forums like this  finding a workaround - but then that takes a lot of time and effort for something that should be easy if it just worked correctly. That seems to defeat the purpose of EDGE in many ways. It took me about three hours to develop my EDGE animation, and now it's going on a third day trying to figure out how to get this very simple feature (scaling to browser size) to work correctly when implemented in a browser.
      Am I missing something, or is this just a bug that still doesn't work in EDGE? Is there an easy fix?
      Any thoughts would be appreciated.
      Thanks everyone
        • 1. Re: Responsive Scaling still not working correctly?
          dajupe Level 1
          I am having the same problem! Going to try a few things before exporting from edge animate. Let us know if you have found a quick solution.
          • 2. Re: Responsive Scaling still not working correctly?
            bobba1 Level 1
            I still haven't had any luck getting the height of responsive scaling to work correctly when added to a website using dreamweaver cc 2014 - it keeps adding white space below the animation - the more white space the smaller the browser scales. Have you had any luck or found any code that would help alleviate this? I think the resize function is not properly resizing the height of the animation to match the width as the width scales down (or up). I keep the width set at 100% in the tag for the animation, FYI. Thanks
            • 3. Re: Responsive Scaling still not working correctly?
              dajupe Level 1
              Absolutely nothing yet. It has been driving me nuts! I am surprised there hasn't been more about it on the internet which makes me think I am doing something wrong.
              I'm considering not making it responsive and using media queries to hide it and swap it with a smaller one for smart devices. But I am sure there is one little thing that will
              fix the problem, darn it!
              If I find a solution I will let you know, good luck with it.
              Cheers
