• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Maximize image quality
New Here ,
May 03, 2007 May 03, 2007
Under Preferences I have set the image quality to 'high' but I still get blurring in images (SnagIt) screen shots which I insert into PowerPoint. When viewing in PPT the images are very clear. But after Presenter has converted them to Flash and published them to Adobe server the images become significantly blurred. Is there any other way to improve the image quality? For example - using a certain file type to insert images into PPT, a setting in PPT, a setting in SnagIt, or a different setting in Presenter? Or, is this just the reality of converting PPT to Flash?
Any help is appreciated
thanks
TOPICS
Presenter
Views
653
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
May 21, 2007 May 21, 2007
LATEST
Unfortunately, Breeze applies some rather heafty compression on bitmap images, including gifs/jpgs and pngs.
Others have reported that you can improve detail of screenshots a bit by using Captivate to capture the screenshots and then export the imagery as a .swf. Then, go back to the Breeze menu and trace down to the Insert Flash option to import the swf created in Captivate. Results are usually better, but it does require having to take an alternative approach. And for folks who don't have Captivate, it might not be a practical approach either.
Two other possible solutions, but both require the right kind of software to do it: If you have other applications that export as .swf (like Illustrator, Freehand, etc), you might want to try importing your screenshot and then exporting as a swf from there, or you could do the same thing right from Flash if you have it.
Hope that helps!
Rob
Votes
Translate
Translate
Report
Report
Resources
Help resources
