4 Replies Latest reply on Jul 13, 2014 11:01 AM by Johnwhite
    Change script function
    Johnwhite Level 1
      Can you change the function of script “find-change-by-list“?
      I want to change in all my opening files.
      main();
      function main(){
      var myObject;
      //Make certain that user interaction (display of dialogs, etc.) is turned on.
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      if(app.documents.length > 0){
        if(app.selection.length > 0){
         switch(app.selection[0].constructor.name){
          case "InsertionPoint":
          case "Character":
          case "Word":
          case "TextStyleRange":
          case "Line":
          case "Paragraph":
          case "TextColumn":
          case "Text":
          case "Cell":
          case "Column":
          case "Row":
          case "Table":
           myDisplayDialog();
           break;
          default:
           //Something was selected, but it wasn't a text object, so search the document.
           myFindChangeByList(app.documents.item(0));
        else{
         //Nothing was selected, so simply search the document.
      else{
        alert("No documents are open. Please open a document and try again.");
      function myDisplayDialog(){
      var myObject;
      var myDialog = app.dialogs.add({name:"FindChangeByList"});
      with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
         with(dialogColumns.add()){
          staticTexts.add({staticLabel:"Search Range:"});
         var myRangeButtons = radiobuttonGroups.add();
         with(myRangeButtons){
          radiobuttonControls.add({staticLabel:"Document", checkedState:true});
          radiobuttonControls.add({staticLabel:"Selected Story"});
          if(app.selection[0].contents != ""){
           radiobuttonControls.add({staticLabel:"Selection", checkedState:true});
      var myResult = myDialog.show();
      if(myResult == true){
        switch(myRangeButtons.selectedButton){
         case 0:
          myObject = app.documents.item(0);
          break;
         case 1:
          myObject = app.selection[0].parentStory;
          break;
         case 2:
          myObject = app.selection[0];
          break;
        myDialog.destroy();
        myFindChangeByList(myObject);
      else{
        myDialog.destroy();
      function myFindChangeByList(myObject){
      var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
      var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit, myStory;
      var myStartCharacter, myEndCharacter;
      var myFindChangeFile = myFindFile("/FindChangeSupport/testing001.txt")
      if(myFindChangeFile != null){
        myFindChangeFile = File(myFindChangeFile);
        var myResult = myFindChangeFile.open("r", undefined, undefined);
         //Loop through the find/change operations.
         do{
          myLine = myFindChangeFile.readln();
          //Ignore comment lines and blank lines.
          if((myLine.substring(0,4)=="text")||(myLine.substring(0,4)=="grep")||(myLine.substring(0, 5)=="glyph")){
           myFindChangeArray = myLine.split("\t");
           //The first field in the line is the findType string.
           myFindType = myFindChangeArray[0];
           //The second field in the line is the FindPreferences string.
           myFindPreferences = myFindChangeArray[1];
           //The second field in the line is the ChangePreferences string.
           myChangePreferences = myFindChangeArray[2];
           //The fourth field is the range--used only by text find/change.
           myFindChangeOptions = myFindChangeArray[3];
           switch(myFindType){
            case "text":
             myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
             break;
            case "grep":
             myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
             break;
            case "glyph":
             myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
             break;
         } while(myFindChangeFile.eof == false);
         myFindChangeFile.close();
      function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
      //Reset the find/change preferences before each search.
      app.changeTextPreferences = NothingEnum.nothing;
      app.findTextPreferences = NothingEnum.nothing;
      var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
      myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
      myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
      app.doScript(myString, ScriptLanguage.javascript);
      myFoundItems = myObject.changeText();
      //Reset the find/change preferences after each search.
      function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
      //Reset the find/change grep preferences before each search.
      app.changeGrepPreferences = NothingEnum.nothing;
      app.findGrepPreferences = NothingEnum.nothing;
      var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
      myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
      myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
      var myFoundItems = myObject.changeGrep();
      //Reset the find/change grep preferences after each search.
      function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
      //Reset the find/change glyph preferences before each search.
      app.changeGlyphPreferences = NothingEnum.nothing;
      app.findGlyphPreferences = NothingEnum.nothing;
      var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
      myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
      myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
      var myFoundItems = myObject.changeGlyph();
      //Reset the find/change glyph preferences after each search.
      function myFindFile(myFilePath){
      var myScriptFile = myGetScriptPath();
      var myScriptFile = File(myScriptFile);
      var myScriptFolder = myScriptFile.path;
      myFilePath = myScriptFolder + myFilePath;
      if(File(myFilePath).exists == false){
        //Display a dialog.
        myFilePath = File.openDialog("Choose the file containing your find/change list");
      return myFilePath;
      function myGetScriptPath(){
      try{
        myFile = app.activeScript;
      catch(myError){
        myFile = myError.fileName;
      return myFile;
        • 1. Re: Change script function
          Jump_Over Level 5
          Notice the last part of a function myDisplayDialog() ==> where it is being decided which parameter became a target of script.
          We can modify this part. Lets change mObject constructor as an array. Main procedure can be called as many times as long is this array. So:
            var cObj;
            case 0:
            myObject = app.documents.everyItem().getElements();     //     array
            break;
            case 1:
            myObject = [app.selection[0].parentStory];     //     array
            break;
            case 2:
            myObject = [ app.selection[0] ];     //     array
            break;
            myDialog.destroy();
            while (cObj = myObject.shift() )     // cutting an array
                 myFindChangeByList(cObj);
          } else {
            myDialog.destroy();
          to be more accurate you could modify this line as well:
          radiobuttonControls.add({staticLabel:"Opened documents", checkedState:true});
          Jarek
          • 2. Re: Change script function
            Johnwhite Level 1
            Hi, Jarek
            I change the script like this:
            main();
            function main(){
            var myObject;
                case "Character":
                case "Word":
                case "Line":
                case "Paragraph":
                case "TextColumn":
                case "Text":
                case "Cell":
                case "Column":
                case "Row":
                case "Table":
                 myDisplayDialog();
                 break;
                default:
              else{
            else{
            var myObject;
              var cObj;
              case 0:
              break;
              case 1:
              break;
              case 2:
              break;
              myDialog.destroy();
            } else {
              myDialog.destroy();
               do{
                 switch(myFindType){
                  case "text":
                   break;
                  case "grep":
                   break;
                  case "glyph":
                   break;
              //Display a dialog.
            return myFilePath;
            try{
            catch(myError){
            return myFile;
            but only work on one file, not the all of my opening files
            • 3. Re: Change script function
              Jump_Over Level 5
              to go across all file a dialog should be called.
              For now only way is to select some text or place a cursor inside any text.
              You can run it this way or paste myDisplayDialog()
              into the lines as screen shows:
              Jarek
              • 4. Re: Change script function
                Johnwhite Level 1
                thanks Jarek
