4 Replies Latest reply on Jul 14, 2014 9:29 AM by creativejoan0425
    Script UI
    creativejoan0425 Level 1
      If have a button, when click "Button 1",it will pop up second dialog and then click "Button 2", need to pop up third dialog
      but can't pop the third dialog, why?
      w = new Window ("dialog", "Test", undefined, {resizeable: true});
      var myText = w.add("edittext", undefined, "", {multiline: true})
      myText.alignment = ["fill", "fill"];
      myText.minimumSize = [300, 30];
      w.location = [55, 140];
      myPrinter = w.add("button", undefined, "Button 1");
      var w2 = new Window ("dialog");
      w2 .add ("button", undefined, "Button 2");
      var w3 = new Window ("dialog");
      w3 .add ("button", undefined, "Button 3");
      myPrinter.onClick = function() {
                 w2.show();
      w3.onClick = function() {
               w3.show();
      w.show();
        • 1. Re: Script UI
          TᴀW Adobe Community Professional & MVP
          Works fine here:
          var i = 0;
          newWindow();
          function newWindow(){
               i++;
               var w = new Window ("dialog", "Window " + i);
               var b = w.add("button", undefined, "New Window");
               b.onClick = newWindow;
               w.onShow = function(){
                   w.location.x = w.location.y = 100 + i *30;
               w.show();
          • 2. Re: Script UI
            Thx but that not what I want
            each button I click have different action to do
            yr script seem click the button the action is the same
            • 3. Re: Script UI
              milligramme Level 3
              w2 .add ("button", undefined, "Button 2"); /// <= HERE
                        w2.show();
              w3.onClick = function() { /// <= AND HERE
                      w3.show();
              w.show();
              Hi, your code is not pointed Button2 ,
              var button2 = w2 .add ("button", undefined, "Button 2");
              set variable and
              button2.onClick = function() {...}
              OR
              w2 .add ("button", undefined, "Button 2", {name: "Button 2"});
              set name and call 'Button 2' element
              w2['Button 2'].onClick = function() {...}
              thank you
              • 4. Re: Script UI
                I fix my button to set variable but when I click button2 can response the action print, is it something wrong?
                       var w1 = new Window ('dialog', 'Test', undefined, {resizeable: true});
                       var myText = w1.add('edittext', undefined, 'TEST', {multiline: true});
                            myText.alignment = ['fill', 'fill']
                            w1.location = [55, 140]
                       var myButton1 = w1.add('button', undefined, 'Button 1')
                        var w2 = new Window ('dialog');
                        var panel1 = w2.add ('panel');
                        var panel2 = w2.add ('Group');
                        var myButton2 = panel2.add('button', undefined, 'myButton2');
                                                 panel2.alignChildren ='right';
                myButton1.onClick = function() {
                    w2.show();
                myButton2.onClick = function() {
                    app.activeDocument.print();
                w1.show();
