3 Replies Latest reply on Jul 17, 2014 9:40 PM by Noel Carboni
    Layered PSD files getting corrupted when applying a gaussian blur.
    sinnottbrossupport Level 1
      A file is created then three layers to keep simple a red square is created using the marquee tool then filled with a colour this is repeated on the next layer with a different colour then the third layer is completely filled with another colour.
      The first two layers are selected and scaled then made transparent.
      Finally the layer in between layer 3 and layer 1 is selected and a gaussian blur is applied this is when the corruption occurs
      Files are being created using Adobe Photoshop CS6 version v13.0.6 and OSX v10.9.3 on Mac Pro with the below specs:
      Model Name: Mac Pro
      Model Identifier: MacPro5,1
      Processor Name: Quad-Core Intel Xeon
      Processor Speed: 2.8 GHz
      Number of Processors: 1
      Total Number of Cores: 4
      L2 Cache (per Core): 256 KB
      L3 Cache: 8 MB
      Memory: 12 GB
      Processor Interconnect Speed: 4.8 GT/s
      ATI Radeon HD 5870:
      Chipset Model: ATI Radeon HD 5870
      Type: GPU
      Bus: PCIe
      Slot: Slot-1
      PCIe Lane Width: x16
      VRAM (Total): 1024 MB
      Vendor: ATI (0x1002)
      Device ID: 0x6898
      Revision ID: 0x0000
      ROM Revision: 113-C0780C-194
      EFI Driver Version: 01.00.436
      Displays
      CG277:
      Resolution: 2560 x 1440
      Pixel Depth: 32-Bit Color (ARGB8888)
      Main Display: Yes
      Mirror: Off
      Online: Yes
      Rotation: Supported
      Connection Type: DisplayPort
      After file is corrupted Photoshop has to be closed and re-opened because subsequent files that are opened are corrupted.
      This has been reported in CS5 and CS5.5 extensively but not so much in CS6.
        • 1. Re: Layered PSD files getting corrupted when applying a gaussian blur.
          Noel Carboni Level 8
          You can reproduce this on demand with a particular document as input?
          Adobe might like to have a copy of a PSD saved from that document (assuming loading it then running Gaussian Blur reproduces the problem).  Can you post it online somewhere, or give explicit instructions on exactly how to create it?
          -Noel
          • 2. Re: Layered PSD files getting corrupted when applying a gaussian blur.
            Below is the steps that where used to create the corruption in the files.
            Gausian Blur corruption in Photoshop
            Step 1. Create document with 3 layers + Background.
            Step 2. Layer 3 - Create a box (Red)
            Step 3. Layer 2 - Create a box (Blue)
            Step 4. Layer 1 – Fill layer (Yellow)
            Step 5. Select layer 3 & 2 & scale down & press
            return
            Step 6. Change opacity of layer 1 & 2 to 25%
            Step 7. Go to layer 2 and select Gaussian Blur filter
            Please Note that the blue & Red Box Have changed
            colour.
            As I Zoom in and out the corruption gets worse.
            Sometimes this corruption dose’nt show up until you have
            saved & reopened the file
            • 3. Re: Layered PSD files getting corrupted when applying a gaussian blur.
              This problem could be specific to your particular system or platform, or something that you didn't mention (like the precise size of the images,how you're filling your rectangles, etc.).
              I just ran through it several times with small and large images, trying to match what you showed above.  Every time my display looks normal at the point of Gaussian Blur (where yours has lost its color), and the operation completes normally and leaves the image uncorrupted.  Hopefully someone with a Mac will try the same steps.
              -Noel
