2 Replies Latest reply: Jul 14, 2014 4:39 AM by BKBK RSS
    CFINCLUDE inside CFMAIL
    jackhuang
      I have a done a CFQUERY and retrieve user's email and name.  Then I try to do a CFMAIL something like:
      <cfmail to="#user.email#" from="sender@somewhere.com" subject="Message from #sender_name#" type="html">
      <table><tr><td>
      Dear #receiver_name#
      </td></tr>
      <tr><td>
      #form.message#
      </td></tr>
      </table>
      </cfmail>
      This seems to work with CFMAIL and the variables are being populated properly.  However, when I placed the content into a template content.cfm because I want to use it somewhere else as well. So content.cfm has:
      <table><tr><td>
      </td></tr>
      <tr><td>
      #form.message#
      </td></tr>
      </table>
      and the program became:
      <cfinclue template="content.cfm">
      </cfmail>
      Now the problem is, I am NOT getting the variables (#receiver_name# and#form.message#) populated by Coldfusion when I use the cfinclue template.  Why?  This is driving me crazy.  I don't know why it doesn't work.    Thanks in advance.
        • 1. Re: CFINCLUDE inside CFMAIL
          duncancumming Community Member
          Try this (usually at this point I'd have two versions, HTML and plaintext):
          <cfsavecontent variable="content"><cfinclude template="content.cfm"></cfsavecontent>
            <cfmailpart type="html">#content#</cfmailpart>
          </cfmail>
          Also wrap content.cfm inside <cfoutput></cfoutput>
          • 2. Re: CFINCLUDE inside CFMAIL
            BKBK ACP/MVP
            Your code works in cfmail because Coldfusion performs cfoutput implicitly within the cfmail tag. The solution is therefore to add the cfoutput tag in content.cfm, as follows:
            <cfoutput>
            <table><tr><td>
            </td></tr>
            <tr><td>
            #form.message#
            </td></tr>
            </table>
            </cfoutput>
            Incidentally, your post has a typo: cfinclue instead of cfinclude. This is just a typo to get out of the way, and has nothing to do with the issue.
