3 Replies Latest reply on Jul 14, 2014 8:54 PM by A.T. Romano
    Export and Paste function are not available
    Caravita
      Hi again, So I cut a clip from my project thinking I could paste it, or press export, but both options are unavailable (whited out). Now I am worried I will lose the clips that I have cut, I cannot do UNDO as I saved the original as is in order to go into a new project, into which I was going to paste it. Duh.
        • 1. Re: Export and Paste function are not available
          A.T. Romano Level 7
          Caravita
          You can "copy or cut" and paste within one project. But you cannot copy and paste between two different projects unless you have Windows and use the ClipMate program in conjunction with Premiere Elements.
          http://www.atr935.blogspot.com/2013/05/pe-clipmate-copypaste-between-pe.html
          And, if you do not want to use ClipMate/Premiere Elements for the copy/paste insert between programs, then...
          If you have content from one project and want to get it into another project, you can use selective export of the segment from the first project and then import that export into the second project. We have already discussed the selective export in depth in another of your threads (Work Bar Area gray tabs set PLUS check mark next to "Share Work Area Bar Only" option in the export settings.) Once you have the export, you import that into the second project as source media with the second project's Add Media/Files and Folders.
          Clips
          In your present situation, go back to the first project and use undo to try to bring back the clip on which you used the "cut" command.
          Please let us know what is happening. Please do not hesitate to let us know if you have questions on this or need further clarification.
          Thank you.
          ATR
          • 2. Re: Export and Paste function are not available
            Caravita Level 1
            thanks ATR.
            I cannot Undo it unfortunately,  i tried that ;/ so worries will just have to re-do it.
            i will try the selective import thing now
            thanks again
            • 3. Re: Export and Paste function are not available
              A.T. Romano Level 7
              Caravita
              Selective export to transfer Timeline content from one project to another is all well and good, but, if you have not already, please
              check your export settings in project 1 for more than just the "Share Work Area Bar Only" option.
              For best results, you want to export your segment from project 1 as a file whose properties are appropriate for the project settings of the second
              project. Details of the export settings from the first project may need some consideration.
              Please let us know if you are OK with the details.
              Thank you.
              ATR
