6 Replies Latest reply on Jul 14, 2014 3:30 PM by myDavey
    Rethread all text frames by current page order
    myDavey Level 1
      Hello
      I made a 'mistake' today, wondering if there is anything to do about it
      • I have an InDi file with 1 story - multi chapter
      • every page is a new chapter (small chapters)
      • I wanted to change the order, so I moved the pages! (not the text)
      • Now, when I am on page 12, if I add text, or press the down arrow, it is going into page 3! etc.
      Is there a way to rethread all text frames?
      I.e., break the current threading, and then rethread each page's frame to the next?
      Any help and guidance will be appreciated
      Davey
        • 1. Re: Rethread all text frames by current page order
          Jump_Over Level 5
          Backup your doc and run this:
          (one of threated textFrames supposed to be selected)
          var
            mFrames = app.selection[0].parentStory.textContainers,
            len = mFrames.length,
            cTxtReflowSet = app.activeDocument.textPreferences.smartTextReflow;
          app.activeDocument.textPreferences.smartTextReflow = false;
          while (len-->0) {
            mFrames[len].nextTextFrame = null;
          mFrames.sort(sortByPage);
          len = mFrames.length;
          while (len-->1)
            mFrames[len].previousTextFrame = mFrames[len-1];
          app.activeDocument.textPreferences.smartTextReflow = cTxtReflowSet;
          function sortByPage (a,b) {
            return a.parentPage.documentOffset > b.parentPage.documentOffset;
          Jarek
          • 2. Re: Rethread all text frames by current page order
            myDavey Level 1
            Hi Jarek
            Thanks a lot for your response
            I dont think this is working properly
            It seems to me that it is putting it back to the order in which it was originally
            Instead, I wanted to thread the text as it appears in the current page order
            Davey
            • 3. Re: Re: Rethread all text frames by current page order
              Jump_Over Level 5
              Yeap,
              The problem is only you can see how it appears. I can just read what you wrote, nothing else.
              You shouldn't ask for "re-threading" frames if your goal is to recompose text. There are different stories.
              I gave you a code to step back from a mistake you wrote about.
              To reach a goal with recomposing I suggest workflow like:
              • duplicate a doc
              • remove main story
              • link frames as page order
              • duplicate particular texts page by page from original doc to a copy
              Assuming 3 steps are done - 4th depends on your doc structure (how many frames on page, how to detect a proper textFrame, is it named?)
              Lets assume you did an empty copy with textFrame linked in page order and there is only one frame per page and a story starts from 1st page.
              Keep source and output opened and activate a source. Then run this:
              var
                sourceDoc = app.activeDocument,
                outputDoc = app.documents[1],
                myTextArray = sourceDoc.pages.everyItem().textFrames.everyItem().texts.everyItem().getElements();
              for (var k=0; k<myTextArray.length; k++)
                myTextArray[k].duplicate(LocationOptions.AFTER, outputDoc.pages[0].textFrames[0].parentStory.texts[0] );
              Jarek
              • 4. Re: Re: Rethread all text frames by current page order
                myDavey Level 1
                Hi Jarek
                Thanks a lot - greatly appreciated!
                Sorry for the confusion, I guess I just didnt have the right terminology.
                _________
                Now, it seems that you are on a much more professional level than me..... I dont understand what you mean
                1. What do you mean by "remove main story"?
                2. When you say "link frames as page order" do you mean by script? Otherwise - how?
                3. I am not sure why #4 is needed.
                Every page has one frame, and originally they were threaded in order of pages.
                Then I re-ordered the pages.
                Would'nt it suffice to just break the current threading and to then rethread it by page order?
                I am making it sound simple, but I dont know how to accomplish this
                Thanks again
                Davey
                • 5. Re: Re: Re: Rethread all text frames by current page order
                  Kai Rübsamen Level 4
                  I’m not sure, if I understand the goal correctly and we talk about the same things if we talk about recomposing or re-threading.
                  I would do the following:
                  1. Use Adobes script split story. This will duplicate all Frames and delete the origin story
                  2. Re-Thread the frames in the order as shown on the document pages
                  3. To prevent any other frames on the page, give the frames before re-threading or recomposing ;-) a name
                  // check selection
                  if ( !( app.selection.length == 1 && ( app.selection[0].hasOwnProperty('baseline') || app.selection[0].constructor.name == "TextFrame" ) )) {
                      alert( "wrong selection!" );
                      exit();
                  var curStory = app.selection[0].parentStory;
                  var curDoc = app.activeDocument;
                  if ( curStory.textContainers.length > 1 ) {
                      mySplitStory( curStory );
                      myRemoveFrames( curStory );
                  relinkTextFrames ( curDoc.textFrames );
                  function mySplitStory( myStory ) {
                      var myTextFrame;
                      //Duplicate each text frame in the story.
                      for( var myCounter = myStory.textContainers.length-1; myCounter >= 0; myCounter -- ) {
                          myTextFrame = myStory.textContainers[myCounter];
                          myTextFrame.name = "linkme";
                          myTextFrame.duplicate();
                  function myRemoveFrames( myStory ) {
                      //Remove each text frame in the story. Iterate backwards to avoid invalid references.
                          myStory.textContainers[myCounter].remove();
                  function relinkTextFrames( myTextFrames ) {
                      var collectTFrames = [];
                      for (var i = 0; i < myTextFrames.length; i++ ) {
                          if ( myTextFrames[i].name == "linkme" ) {
                              collectTFrames.push(myTextFrames[i]);
                      for ( var n = 0; n < collectTFrames.length-1; n++ ) {
                          var curTFrame = collectTFrames[n];
                          var nextTFrame = collectTFrames[n+1];
                          curTFrame.nextTextFrame = nextTFrame;
                  • 6. Re: Re: Re: Rethread all text frames by current page order
                    myDavey Level 1
                    Hi Kai
                    That's exactly what I needed! - Worked perfectly
                    Thanks a lot!
                    Davey
