1 Reply Latest reply on Aug 25, 2007 11:53 AM by Greg Dove
    problems with removeMovieClip()
    DZ-015 Level 1
      Hey - I'm having problems removing a movie clip I created with attachMovie. the movie clip has many other movie clips inside it. But when use:
      mcStack doesn't disappear. Is there something I have to do first to make removeMovieClip work?
      BTW - mcStack is in scope from where I'm trying to use removeMovieClip... if I say mcStack._alpha = 50; it goes transparent. I just can't get it to go away! :-P
        • 1. Re: problems with removeMovieClip()
          Greg Dove Level 4
          I would tend to use
          but I don't think that would make any difference.
          what number do you get if you try
          it might be out of range for removal - are you using getNextHighestDepth() when you originally attach it - and possibly some components as well>. (I don't actually know what might happen if one of its child clips are assigned an 'out of range' depth - whether you can remove the parent clip or not.)
          If the trace gives you an extremely high number or a negative number then just try something like:
          mcStack.swapDepths(9999); //a depth where no other movieclip exists
