4 Replies Latest reply on May 7, 2015 8:48 PM by bp021868
    Is anyone using Adobe Presenter 10 with PowerPoint 2013?
    Mmissenda
      I was online with the chat support who was trying to help me solve my Adobe Presenter 10 addin in problem with Powerpoint 2013.  He had me remove the software.  When I went to reinstall, the browser logged me off the chat.   When I went back in, they were gone for the day.   Now I have no presentation which was due to be uploaded last Saturday!   Can anyone help?
        • 1. Re: Is anyone using Adobe Presenter 10 with PowerPoint 2013?
          alpi agarwal Adobe Employee
          What is your OS Win 7/Win8  ?
          What is the version of your PowerPoint ?  Is it 2013 32bit or 2013 64 bit ?
          Did you try installing the presenter again ? What error message are you getting ?
          Alpi Agarwal
          Adobe Presenter Engineering Team
          • 2. Re: Is anyone using Adobe Presenter 10 with PowerPoint 2013?
            Mmissenda Level 1
            Hi Alpi,
            After uninstalling Office 365 (powerpoint 2013 32bit) and reinstalling it , I was able to get the addin to work.
            Before this I reinstalled Adobe Presenter 10 , 3 times without success.
            I am using OS WIN 7
            So this solved my addin issue.   It did not solve my issue with my presentation missing the audio files.    When I publish the presentation in HTML it opens in Firefox perfectly.    But when I go to send the packaged  OR zip files they are missing the audio files.   No where to be found  but it has sound in Firefox HTML.    In the end I copied the audio files from a folder I found , into the folder to share.  Then zip the file using Windows.
            I won't know if it worked because the network administrator is not back til tomorrow.
            Thanks for trying to assist me with this.   It has been a long day trying to resolve this issue.   I almost wish I had just redone the lecture in powerpoint and skipped the Adobe Presenter 10.   It may have taken me 2 or 3 hours.  But this is better than the 10 hours it took to deal with this issue.
            Have a good night
            Marybeth
            • 3. Re: Is anyone using Adobe Presenter 10 with PowerPoint 2013?
              Hi Marybeth,
              What are you trying to share . Is it the published output or the presentation (pptx) itself ?
              In case you are sharing the pptx, please use the package option under Presenter ribbon
              If you want to share the published output, please zip the published output folder. It should play fine on all browsers.
              If you are still facing problem, could you please share the zip/package with me at alpagarw@adobe.com ?
              Alpi Agarwal
              • 4. Re: Is anyone using Adobe Presenter 10 with PowerPoint 2013?
                bp021868
                Hi, Alpi,
                I just came across this post and am having several of the same issues.  The add in is showing on the menu bar, but it is not working properly.  I've uninstalled/reinstalled it 3 times, am using Windows 7 and Powerpoint 2013.  My issue is that when I try to import audio, Presenter freezes up and I have to use the Task Manager to exist out of Powerpoint and start all over.  Also when there is audio on a slide (someone from the Adobe support team was able to import 1 audio file for me somehow), the box that pops open to sync the audio and the animation is missing buttons - either the play button doesn't show up, the box is cut off at the bottom and I can't see the scroll bar to fast forward the audio and/or the next slide arrows are missing.
                Any ideas?
                Barbie
