2 Replies Latest reply on Jul 15, 2014 4:39 AM by ZSam
    Audition CC Startup crash/error
    ZSam
      Adobe Audition crashes when it starts up everytime, what happened?
      Here's the crash log:
      LevelDate and TimeSourceEvent IDTask Category
      Error15/07/2014 18:06:18Application Error1000(100)"Faulting application name: Adobe Audition CC.exe, version: 7.0.0.118, time stamp: 0x537b7f08
      Faulting module name: AuUI.dll, version: 7.0.0.118, time stamp: 0x537b7ee7
      Exception code: 0xc0000005
      Fault offset: 0x000000000001629e
      Faulting process id: 0x21c0
      Faulting application start time: 0x01cfa014692ab251
      Faulting application path: C:\Program Files\Adobe\Adobe Audition CC 2014\Adobe Audition CC.exe
      Faulting module path: C:\Program Files\Adobe\Adobe Audition CC 2014\AuUI.dll
      Report Id: a954ec0d-0c07-11e4-827a-448a5b457514
      Faulting package full name:
      Faulting package-relative application ID: "
      It seems to have something to do with AuUI.dll
      DXDIAG
      System Information
      Time of this report: 7/15/2014, 18:20:25
             Machine name: MSI
         Operating System: Windows 8.1 Single Language 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
                 Language: English (Regional Setting: English)
      System Manufacturer: Micro-Star International Co., Ltd.
             System Model: GP60 2PE
                     BIOS: E16GHIMS.109
                Processor: Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz (8 CPUs), ~2.5GHz
                   Memory: 8192MB RAM
      Available OS Memory: 8110MB RAM
                Page File: 5124MB used, 5928MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 11
      DX Setup Parameters: Not found
         User DPI Setting: 120 DPI (125 percent)
      System DPI Setting: 120 DPI (125 percent)
          DWM DPI Scaling: Disabled
           DxDiag Version: 6.03.9600.16384 64bit Unicode
      Display Devices
                Card name: Intel(R) HD Graphics 4600
             Manufacturer: Intel Corporation
                Chip type: Intel(R) HD Graphics Family
                 DAC type: Internal
              Device Type: Full Device
               Device Key: Enum\PCI\VEN_8086&DEV_0416&SUBSYS_11131462&REV_06
           Display Memory: 1792 MB
         Dedicated Memory: 0 MB
            Shared Memory: 1792 MB
             Current Mode: 1920 x 1080 (32 bit) (60Hz)
             Monitor Name: Generic PnP Monitor
            Monitor Model: unknown
               Monitor Id: LGD0259
              Native Mode: 1920 x 1080(p) (59.934Hz)
              Output Type: Internal
              Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
      Driver File Version: 10.18.0010.3621 (English)
           Driver Version: 10.18.10.3621
              DDI Version: 11.1
           Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
             Driver Model: WDDM 1.3
      Graphics Preemption: DMA
      Compute Preemption: Thread
                 Miracast: Supported
      Hybrid Graphics GPU: Integrated
           Power P-states: Not Supported
        Driver Attributes: Final Retail
         Driver Date/Size: 5/21/2014 00:33:40, 16586584 bytes
              WHQL Logo'd: Yes
          WHQL Date Stamp:
        Device Identifier: {D7B78E66-4756-11CF-F779-1931BBC2C735}
                Vendor ID: 0x8086
                Device ID: 0x0416
                SubSys ID: 0x11131462
              Revision ID: 0x0006
      Driver Strong Name: oem29.inf:5f63e534dd929195:iHSWM_w81:10.18.10.3621:pci\ven_8086&dev_0416
           Rank Of Driver: 00DA2001
              Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
              DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT
                Card name: NVIDIA GeForce 840M
             Manufacturer: NVIDIA
                Chip type: GeForce 840M
                 DAC type: Integrated RAMDAC
              Device Type: Render-Only Device
               Device Key: Enum\PCI\VEN_10DE&DEV_1341&SUBSYS_11131462&REV_A2
           Display Memory: 4020 MB
         Dedicated Memory: 1972 MB
            Shared Memory: 2048 MB
             Current Mode: n/a
              Driver Name: nvd3dumx,nvwgf2umx,nvwgf2umx,nvd3dum,nvwgf2um,nvwgf2um
      Driver File Version: 9.18.0013.3788 (English)
           Driver Version: 9.18.13.3788
              DDI Version: 11
           Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
      Compute Preemption: DMA
                 Miracast: Not Supported by Graphics driver
      Hybrid Graphics GPU: Discrete
         Driver Date/Size: 5/20/2014 10:44:03, 17480432 bytes
              WHQL Logo'd: Yes
          WHQL Date Stamp:
        Device Identifier: n/a
                Vendor ID: 0x10DE
                Device ID: 0x1341
              Revision ID: 0x00A2
      Driver Strong Name: oem28.inf:0f066de3569b1e91:Section151:9.18.13.3788:pci\ven_10de&dev_1341&subsys_11131462
           Rank Of Driver: 00DA0001
              Video Accel: n/a
              DXVA2 Modes:
            Deinterlace Caps: n/a
             D3D9 Overlay: n/a
                  DXVA-HD: n/a
             DDraw Status: Enabled
               D3D Status: Enabled
               AGP Status: Enabled
        • 1. Re: Audition CC Startup crash/error
          ryclark Adobe Community Professional
          Did it work OK before? Did anything change on your PC, Windows updates etc.?
          It could be that one of the Audition configuration files has become corrupted. Try renaming the Audition settings folder to something like "6.0.bak"  which will cause Audition to recreate the default settings folder when you open the software again. If that works you can try copying various of the settings .xml files back from your renamed folder if you have any customised settings there. the folder can be found at:
          C:\Users\"username"\AppData\Roaming\Adobe\Audition\6.0 where "username" is your username.
          Otherwise re-installing Audition might solve the problem.
          • 2. Re: Audition CC Startup crash/error
            ZSam Level 1
            Reinstalling solved the problem, thank you.
