4 Replies Latest reply on Jul 16, 2014 3:10 AM by Bob McAlpine
    Corrupt catalogue
    Bob McAlpine
      I am using Lightroom-4 with my photos stored on a network drive.  My number of photos is quite large (perhaps 40,000).  Everything was working well. I decided to add several previous years of photos from backup CDs and was able to download all of these successfully into my Lightroom catalogue (perhaps now totally 80,000 pictures with a file storage of 100GB.  I closed the catalogue to backup the catalogue containg all files, and the backup failed, and a popup told me to close and open the catalogue to repair it. I tried closing and opening LR and ran the repair routime several times and it failed saying that in the download of files from a CD the catalogue was corrupted.  What do I do to repair this catalogue.
        • 1. Re: Corrupt catalogue
          If the built-in repair routines can't fix the catalog, I don't believe there is anything you can do. You will probably have to revert to your most recent good back up, and start the import process again. As you build this new catalog  again you should probably consider backing up more frequently. I wonder if it's possible that one of your CDs was corrupted.
          • 2. Re: Corrupt catalogue
            Bob McAlpine Level 1
            Thank you Jim.  I do believe that there were errors on one of the CDs because it contained images that could not be read.  I am rebuilding the catalogue from the most recent backup; but it will be a lot of work.
            Robert
            • 3. Re: Corrupt catalogue
              Computers are great, until they're not.
              • 4. Re: Corrupt catalogue
                I went back to my most recent backup with the intent to parse my large database into component catalogs and add from there so instead of one very large catalog (or about 80K pictures), I would have two catalogs of 40K each.  However, when I went back to my most recent backup (having 55K images) as my starting point, I found the following:  This version ran well; but when I tried to back it up, the optimization routine ran continuously for over 7-hours.  The Windows Task Master showed that LR4 was still running, even after 7-hours. I suspect something is wrong with this backup version and I could go back to the previous backup version (since this one obviously backed up properly, it might be a better starting point to parse build up my database.  Would upgrading to LR5 help?  Presumably LR5 has better repair functions than LR4 (one might hope).   Maybe I need to get paid help from Adobe to proceed in my repairs so I don't inadvertently make matters worse.
