Hello,
Thanks for taking a look and for any ideas you might have.
Rob
ColdFusion app errors when attempting to query MSSQL 2008 R2 databse via SSL connection.
The datasource verifies fine.
I have EncryptionMethod=SSL;validateServerCertificate=false for connection string.
Setting a trace on the SQL server doesn't show it trying to hit the database at all.
I have a copy of the same database on a SQL Server 2012 box (this one is server core if it matters). I can edit the datasource to just point to this server and the app works fine.
Both SQL servers require SSL.
Here is the first few lines of a coldfusion log of database calls.
spy(Thread-66)(2014/07/15 16:07:53.353)>> Connection[1].getMetaData()
spy(Thread-66)(2014/07/15 16:07:53.353)>> java.sql.SQLException: [Macromedia][SQLServer JDBC Driver]Object has been closed. ErrorCode=0 SQLState=HY000
at macromedia.jdbc.sqlserverbase.ddca.b(Unknown Source)
at macromedia.jdbc.sqlserverbase.ddca.a(Unknown Source)
at macromedia.jdbc.sqlserverbase.ddb9.b(Unknown Source)
at macromedia.jdbc.sqlserverbase.ddb9.a(Unknown Source)
I figured my problem out today, hope it helps with yours.
See this link.
http://support.microsoft.com/kb/2653857
I installed an old JRE (6 update 27) and it fixed the problem.
We are catching the patches up on our server tonight.
Rob
I am having the same problem connecting to the same type of sql server. I thought it was because the connection string had to be more detailed.
See this link.
Rob
Hi Rob,
Interesting fix. I wonder if the more recent java 7 does not have SQL trusted ssl certificate information in it's keystore?
It would be interesting to use current java 7 with the keystore file jre\lib\security\cacerts from jre 6u27.
Just pondering, Carl.
Just to be clear, we'll go back to java 7 after we get our server patched according to the info in the article.
Server was patched overnight, I removed the old version of Java this morning. Everything looks good.
Rob
As far as simply making ssl the connection, I found a nice and very helpful step through checklist at Re: SSL Encryption for Data Sources: which I'm describing here:
I had a very difficult time finding this information so I hope this can be helpful.
