Hi all i was prompted to install the new flash update,
i tried to install at first i was getting an error with safari being open, when it was closed, i had forced quit the browser
and also checked Activity Manager to make sure it was shut.
after reading the adobe help information i uninstalled flash and restarted the computer, i started the process again
the safari problem did not come up apon the new install, But i had a new problem i get a general error at around 75-85%,
of the install.e
so now i have no flash player, i read the forums there is another thread that links, install_flash_player_osx-.dmg
some people saying that this works for OS 10.9.4, so i tried this option but now the file does not pass the download stage of the install at around 20%.
and the same old General error comes up again leaving me stuck, i am a stay at home dad that builds websites and i need Flash Player.
any help would be greatly welcomed.
There is no such installer; the offline installer is http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
Hi Pat,
That is the file i was talking about when you click the link you provided that is the name of the file
i get an error even faster with that fix.
Hi Kiwi,
Can you please provide the following two log files:
The content of both files will be fairly large to post here, as such, please use the How to share a document instructions to share the files.
Thank you.
Maria
Hi Maria thanks for the quick reply
here is a link to the files you requested
thanks for your help in advance
Shane
Hi Maria,
I'm having issues with the flash update as well. Install times out after 30%. I tried downloading the offline installer, but the link that Pat listed above doesn't work. Says "Safari can't connect to server." Do you have another link we can try? Thanks in advance.
Cheers!
I too was unable to install the flash player. It would download but upon attempting to install it would freeze and tell me to close Safari even though it was not running. I downloaded the player from the offline link Pat provided and it installed without issue. By the way, thanks Pat.
Hi nikondvr ,
i had the same issue except the offline installer also failed to work glad the issue is sorted for you
Kiwi
@Kiwisox
Thank you for providing the files. I didn't get a chance to look at them yesterday, but will do so today.
@Odawg76,
Please start a new thread with your issue, as it appears to be different from Kiwisox. It is also difficult to respond to various users in the same thread and keep responses relevant to each individual as the forums software doesn't nest responses to individual users, but lists everything chronologically. Please follow the guidelines here, Please read this before you post!, when creating your new thread. I've actually not seen the "Safari can't connect to server" returned by the Flash Player installer. Please include a screenshot of the error. Instructions available here, How to post a screenshot in the forum. Thank you.
@nikondvr
You're issue appears to be different from Kiwisox. On Mac, simply closing an application window does not quit the application. You need to actually terminate Safari for Flash Player installation to proceed.
There are a few different ways to Quit Safari:
Quit Safari app from the Dock icon:
Mouse over the Safari icon in the Dock
Press CTRL and left-mouse click at the same time
A menu will display. Click Quit to terminate the application.
Use Activity Monitor to terminate Safari:
Launch Activity Monitor from Applications/Utilities/Activity Monitor
Ensure 'All Processes' are being listed (menu in the upper right)
Find and select Safari
Click the Quit Process button (upper left)
Maria
Hi Kiwisox,
Unfortunately, the FlahPlayerInstallManager.log file was empty and the install.log file did not contain information for the current installation you are attempting. Can you please provide one more log file, by following these instructions:
Thank you.
Maria
Finally After a month of frustrating hair pulling i found a forum from 2011 that gave me the answer to my problems
after the update and the uninstall of the flashplayer my permissions got damaged no idea how or why
but this video explained what to do to sort it
it was also affecting my adobe cloud i could not install new apps or update
thanks for all the replys
