0 Replies Latest reply on Jul 15, 2014 5:13 PM by AbsoluteOlly
    Save for web error
    AbsoluteOlly
      So I'm having trouble with this error message coming up when I'm trying to make stuff. (The Operation could not be completed") At the moment I have been trying to make a fairly large giff, that, for whatever reason is 400mb, after i go in to save for web and attempt to optimize it, i get this message, it has worked before, however i can't seem to save my file as a gif, if you happen to know how i can solve this as well, i can only seem to save it as HTML or JPEG.
      I have tried re-opening PS
      My System info off PS CC I have seen this problem posted here before and it was solved through lack of memory, however i have 32gb RAM so i figure that is not the issue, is there a way to allocate more memory to PS? Thanks!
      Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
      Operating System: Windows 8 64-bit
      Version: 6.2
      System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
      Physical processor count: 4
      Logical processor count: 8
      Processor speed: 2394 MHz
      Built-in memory: 32655 MB
      Free memory: 29156 MB
      Memory available to Photoshop: 29573 MB
      Memory used by Photoshop: 60 %
      Image tile size: 1024K
      Image cache levels: 4
      Font Preview: Medium
      TextComposer: Latin
      Display: 1
      Display Bounds: top=0, left=0, bottom=1080, right=1920
      Display: 2
      Display Bounds: top=0, left=1920, bottom=720, right=3200
      OpenGL Drawing: Enabled.
      OpenGL Allow Old GPUs: Not Detected.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      AIFCoreInitialized=1
      AIFOGLInitialized=1
      OGLContextCreated=1
      NumGPUs=1
      gpu[0].OGLVersion="3.0"
      gpu[0].MemoryMB=2080
      gpu[0].RectTextureSize=16384
      gpu[0].Renderer="Intel(R) HD Graphics 4600"
      gpu[0].RendererID=4511
      gpu[0].Vendor="Intel"
      gpu[0].VendorID=4318
      gpu[0].HasNPOTSupport=1
      gpu[0].DriverVersion="10.18.10.3412"
      gpu[0].Driver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10 iumd32"
      gpu[0].DriverDate="20140122000000.000000-000"
      gpu[0].CompileProgramGLSL=1
      gpu[0].TestFrameBuffer=1
      gpu[0].OCLPresent=1
      gpu[0].OCLVersion="1.2 "
      gpu[0].CUDASupported=0
      gpu[0].OCLBandwidth=2.10416e+010
      gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 10.18.10.3412"
      gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
      gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
      gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
      gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
      gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
      gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
      gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
      gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
      License Type: Subscription
      Serial number: 90970228348919035075
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
      Temporary file path: C:\Users\oliver\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Startup, 356.3G, 18.7G free
      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
      Installed components:
        ACE.dll ACE 2013/10/29-11:47:16 79.548223 79.548223
        adbeape.dll Adobe APE 2013/02/04-09:52:32 0.1160850 0.1160850
        AdobeLinguistic.dll Adobe Linguisitc Library 7.0.0
        AdobeOwl.dll Adobe Owl 2013/10/25-12:15:59 5.0.24 79.547804
        AdobePDFL.dll PDFL 2013/10/29-11:47:16 79.508720 79.508720
        AdobePIP.dll Adobe Product Improvement Program 7.0.0.1786
        AdobeXMP.dll Adobe XMP Core 2013/10/29-11:47:16 79.154911 79.154911
        AdobeXMPFiles.dll Adobe XMP Files 2013/10/29-11:47:16 79.154911 79.154911
        AdobeXMPScript.dll Adobe XMP Script 2013/10/29-11:47:16 79.154911 79.154911
        adobe_caps.dll Adobe CAPS 7,0,0,21
        AGM.dll AGM 2013/10/29-11:47:16 79.548223 79.548223
        ahclient.dll AdobeHelp Dynamic Link Library 1,8,0,31
        aif_core.dll AIF 5.0 79.534508
        aif_ocl.dll AIF 5.0 79.534508
        aif_ogl.dll AIF 5.0 79.534508
        amtlib.dll AMTLib (64 Bit) 7.0.0.249 BuildVersion: 7.0; BuildDate: Thu Nov 14 2013 15:55:50) 1.000000
        ARE.dll ARE 2013/10/29-11:47:16 79.548223 79.548223
        AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
        AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
        Bib.dll BIB 2013/10/29-11:47:16 79.548223 79.548223
        BIBUtils.dll BIBUtils 2013/10/29-11:47:16 79.548223 79.548223
        boost_date_time.dll DVA Product 7.0.0
        boost_signals.dll DVA Product 7.0.0
        boost_system.dll DVA Product 7.0.0
        boost_threads.dll DVA Product 7.0.0
        cg.dll NVIDIA Cg Runtime 3.0.00007
        cgGL.dll NVIDIA Cg Runtime 3.0.00007
        CIT.dll Adobe CIT 2.1.6.30929 2.1.6.30929
        CITThreading.dll Adobe CITThreading 2.1.6.30929 2.1.6.30929
        CoolType.dll CoolType 2013/10/29-11:47:16 79.548223 79.548223
        dvaaudiodevice.dll DVA Product 7.0.0
        dvacore.dll DVA Product 7.0.0
        dvamarshal.dll DVA Product 7.0.0
        dvamediatypes.dll DVA Product 7.0.0
        dvaplayer.dll DVA Product 7.0.0
        dvatransport.dll DVA Product 7.0.0
        dvaunittesting.dll DVA Product 7.0.0
        dynamiclink.dll DVA Product 7.0.0
        ExtendScript.dll ExtendScript 2013/10/30-13:12:12 79.546835 79.546835
        FileInfo.dll Adobe XMP FileInfo 2013/10/25-03:51:33 79.154511 79.154511
        filter_graph.dll AIF 5.0 79.534508
        icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
        icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
        imslib.dll IMSLib DLL 7.0.0.145
        JP2KLib.dll JP2KLib 2013/10/29-11:47:16 79.248139 79.248139
        libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
        libiomp5md.dll Intel(R) OMP Runtime Library 5.0
        libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
        LogSession.dll LogSession 2.1.2.1785
        mediacoreif.dll DVA Product 7.0.0
        MPS.dll MPS 2013/10/29-11:47:16 79.535029 79.535029
        msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.8428
        msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
        msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
        msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.8428
        msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
        msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
        msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.8428
        msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
        PatchMatch.dll PatchMatch 2013/10/29-11:47:16 79.542390 79.542390
        pdfsettings.dll Adobe PDFSettings 1.04
        Photoshop.dll Adobe Photoshop CC CC
        Plugin.dll Adobe Photoshop CC CC
        PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 4.2.0.36
        PSArt.dll Adobe Photoshop CC CC
        PSViews.dll Adobe Photoshop CC CC
        SCCore.dll ScCore 2013/10/30-13:12:12 79.546835 79.546835
        ScriptUIFlex.dll ScriptUIFlex 2013/10/30-13:12:12 79.546835 79.546835
        svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
        tbb.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
        tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 1, 2012, 1003
        updaternotifications.dll Adobe Updater Notifications Library 7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 7.0.1.102
        WRServices.dll WRServices Mon Feb 25 2013 16:09:10 Build 0.19078 0.19078
