3 Replies Latest reply on Jul 16, 2014 11:08 PM by FieryPantone
    Change Bars don't appear in CHM output? (Frame12)
    David :D Level 1
      Hmmm, one of Frame's more useful features in recent years (for assisting with document reviews) was the ability to automatically add change bars in the margin.
      However, these do not seem to make it through to CHM files if I use Frame 12's "Publish" command to generate HTML Help.
      Is this another one of those little "integration niggles" that Adobe haven't quite managed to solve yet?
        • 1. Re: Change Bars don't appear in CHM output? (Frame12)
          Arnis Gubins Adobe Community Professional & MVP
          RoboHelp (nor Flare) doesn't have or support change bars, so the FM Publish utilities won't have them either. You'll  have to come up with some other method of indicating changes in the CHM. Possible candidates include Character tags (you can search & replace for Change bars using Character Formats) or Conditional text. In both cases having different background colours for different versions/releases would give similar results to change bars (bu you would then be able to track changes over multiple releases, whereas change bars have to be reset every time).
          • 2. Re: Change Bars don't appear in CHM output? (Frame12)
            David :D Level 1
            I find the Publish command's truculent refusal to show me the same stuff in my CHM that I had on screen in Frame increasingly tedious.
            It'll start removing certain big words next, as they're "not supported" in RoboHelp.
            • 3. Re: Change Bars don't appear in CHM output? (Frame12)
              FieryPantone Level 3
              I feel a nuance coming on … in an earlier position, I produced goodness knows how many releases of some regulatory documentation; management were delighted that with judicious use of conditionals we could save all the release history in the same file(s). Version 1, new_v1 condition set to display with change bars and deleted_v1 with strikethrough; Version 2, new_v2 with change bars, new_v1 without, deleted_v1 hidden. So I was resetting the conditional text display, but for my own benefit.
              A pity that .html-based ouput hasn't caught up with .pdf, though.
