7 Replies Latest reply on Jul 17, 2014 8:12 AM by A.T. Romano
    WMV error when attempting to add media.  "Importer reported a generic error"
    slavoie13
      I receive this error "Importer reported a generic error" when attempting to add files for edit.  Has anyone had an issue like this and found a fix?
        • 1. Re: WMV error when attempting to add media.  "Importer reported a generic error"
          From the Premiere Elements Information FAQ http://forums.adobe.com/thread/1042180
          •You MUST use an account with Administrator Privileges to run Premiere Elements
          •(Doing Run as Administrator http://forums.adobe.com/thread/969395 [says Encore and also for "All" versions of Premiere] will sometimes fix "odd" errors)
          •What version of Premiere Elements? Include the minor version number (e.g., Premiere Elements 12 with the 12.0.1 update).
          •What operating system? This should include specific minor version numbers, like "Mac OSX v10.6.8"---not just "Mac"
          •Has this ever worked before?  If so, do you recall any changes you made to Premiere Elements, such as adding Plug-ins, brushes, etc.?  Did you make any changes to your system, such as updating hardware, printers or drivers; or installing/uninstalling any programs?
          •Have you installed any recent program or OS updates? (If not, you should. They fix a lot of problems.)
          •What kind(s) of image file(s)? When talking about camera raw files, include the model of camera.
          •If you are getting error message(s), what is the full text of the error message(s)?
          •What were you doing when the problem occurred?
          •What other software are you running?
          •Tell us about your computer hardware. How much RAM is installed?  How much free space is on your system (C:) drive?
          And some other questions...
          •What are you editing, and does your video have a red line over it BEFORE you do any work?
          •Which version of Quicktime do you have installed?
          • 2. Re: WMV error when attempting to add media.  "Importer reported a generic error"
            slavoie13 Level 1
            Hi John,  please see my responses inline below.
                 Done
                 Running Premiere Elements 12.1
                 Windows 7 OS
                 This is my first time using Adobe Premiere Elements
                 I just installed the version 12 update, unfortunately the update didn't fix the issue.
                 Not an image but a WMV video file
                 uploading a wmv video to premiere elements
                 Chrome, outlook,
                      16gb RAM and 700 gb free space
                 WMV video clip, there is no red line over the file
                 Quicktime is not installed
            Thanks for the speedy follow-up.
            • 4. Re: WMV error when attempting to add media.  "Importer reported a generic error"
              slavoie13 Level 1
              Thanks John, any other suggestions?  I installed Quicktime and I still receive the same error.
              • 5. Re: WMV error when attempting to add media.  "Importer reported a generic error"
                A.T. Romano Level 7
                slavoie13
                Thank you for the information on your issue that you have supplied so far. The focus needs to be on the properties of the source media
                and how the file is being imported into the project.
                Premiere Elements 12/12.1 on Windows 7 (presumed 64 bit).
                (Please double check to make sure that when you go to Publish+Share/Computer/QuickTime, you have
                presets there and not just blank spaces.)
                What is the source of this .wmv file that you are trying to import into the project and getting the Generic Error message?
                What are the properties of the file..
                Video Compression
                Audio Compression
                Frame Size
                Frame Rate
                Pixel Aspect Ratio
                Duration
                By any chance is this .wmv from a screen capturing program? If so, which one and what settings did you select for the output
                from the screen capturing program?
                How are you importing this .wmv into the project - Add Media/Files and Folders (from the computer hard drive)/Project Assets or other?
                Are you setting the project preset manually for this project or letting the program do it for you?
                The answers should be in those details.
                We will be watching for your reply.
                Thank you.
                ATR
                • 6. Re: WMV error when attempting to add media.  "Importer reported a generic error"
                  slavoie13 Level 1
                  Hello ATR
                       All of the spaces are populated.
                  Video Compression - ???
                  Audio Compression-???
                  Frame Size - 1600 w x 900 h
                  Frame Rate - 29 frames per second
                  Pixel Aspect Ratio
                  Duration - 00:55:20
                  By any chance is this .wmv from a screen capturing program?  This is a meeting the was recorded from Goto Meeting
                  If so, which one and what settings did you select for the output from the screen capturing program? The out put would be the gotomeeting default settings.
                  I am importing via Add Media/Files and Folders from the computer hard drive. I have also tried to drag the file onto the drop files here panel, both result in the same error.
                  Are you setting the project preset manually for this project or letting the program do it for you? Letting the project preset for me.
                  Thanks for the help.
                  • 7. Re: WMV error when attempting to add media.  "Importer reported a generic error"
                    A.T. Romano Level 7
                    slavoe13
                    Thanks for the reply and very helpful details.
                    Your answer appears to target Go To Meeting and use of its proprietary video format (a known issue for video editors, including Premiere Elements). But Go To Meeting offers two choices for its output - one using this proprietary video format and another "standard wmv format". I believe that use of the proprietary video format is the default, and you used that instead of the standard wmv format choice.
                    Online is loaded with conversion details for getting the proprietary video format into a standard wmv format if the recordings have already been made.
                    Here is but one
                    https://vzaar.com/help/kb/encoding-questions/encoding-videos-recorded-from-gotomeeting
                    Please review and consider and then let us know the outcome. Any questions on this or need clarification, please do not hesitate to ask.
                    Thank you.
                    ATR
