3 Replies Latest reply on Apr 27, 2007 6:58 AM by HKabaker
    Missing TOC of WebHelp in IE7
    robert_sfl Level 1
      When I view a WebHelp generated with RH2002 in IE7 then the TOC does not display. Is there anything I can do about this, perhaps a specific property of the IE that needs to be set?
        • 1. Re: Missing TOC of WebHelp in IE7
          MergeThis Level 4
          Are you launching the actual start page (most authors usually call them index.htm or start.htm)? It'll also have two related files called filename_csh.htm and filename_rhc.htm.
          If those three files don't appear, you're probably opening source files instead.
          Leon
          • 2. Re: Missing TOC of WebHelp in IE7
            robert_sfl Level 1
            Leon, thanks but this is the start page. I can open the same page in IE6 and the help displays fine. To be more precise, the navigantion pane displays in IE7 but the TOC entries are missing. The search is OK.
            I should add that the topics in this project were edited with HoTMetaL but this should not be a problem I think.
            • 3. Re: Missing TOC of WebHelp in IE7
              HKabaker Level 2
              Things to check:
              Browser setting to allow ActiveX.
              Browser setting not to block popups.
              Output files are present in whdata, whgdata and whxdata directories.
              If you don't have those files, check RH WebHelp setting to generate DHTML, Applet. Navigation pane needs DHTML. Not sure about Applet, but it has benefits.
              Harvey
