6 Replies Latest reply on Jul 19, 2014 4:29 PM by Johnwhite
    Can you make a script for modify cells?
    Johnwhite Level 1
      Hi, every one,
      I am looking for a script can do this:
      If a slection a range of cell, the script can:
      (1) let the even number of column apply to character style “Color+Bold”
      (2) fill with colour of “\d% of PANTONE .+”
      before modify:
      after modify:
      SOMETIMES NEED TO
      (3) fill with boundary line colour of “PANTONE .+”
      John
        • 1. Re: Can you make a script for modify cells?
          Kai Rübsamen Level 4
          Hi John,
          this is the first time, that I write a script, that should style only selected cells. So maybe a bit to complicated, but for me works this one.
          You could enter in the lines 14-16 your informations. The script will have a look at your selection and will formating every second column in the selection.
          It should work with selected rows, but also if you select only parts of e.g. column 3-6 or if you select the whole table.
          It will not check, if your entered color or characterstyle is valid.
          if ( app.selection.length > 0 && ( app.selection[0].constructor.name == "Cell" || app.selection[0].constructor.name == "Table" ) ) {
              if ( app.scriptPreferences.version >= 6 ) {
                  app.doScript( main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "style every second column in selection" );
              else {
                  main();
          } else {
              alert ( "Nothing or wrong selection!" );
          function main() {
              var myColor = "Black";
              var myFillTint = 20;
              var myCharStyleName = "bold";
              var curSel = app.selection[0];
              var allCells = curSel.cells;
              var startCol = curSel.cells[0].name.split(":")[0]*1;
              var endCol = curSel.cells[-1].name.split(":")[0]*1;
              var counter = startCol + 1;
              for ( var i = 0 ; i < allCells.length; i++ ) {
                  var curCell = allCells[i];
                  var curCol = curCell.name.split(":")[0]*1;
                  if ( curCol == counter ) {
                      curCell.fillColor = myColor;
                      curCell.fillTint = 20;
                      curCell.texts[0].appliedCharacterStyle = myCharStyleName;
                      counter = counter + 2;
                  if ( counter > endCol ) {
                  } // end if
              } // end for
          } // end main
          • 2. Re: Can you make a script for modify cells?
            Johnwhite Level 1
            Hi, Kai Rübsamen,
            It was amazing,you wrote this script, it runs very well.
            thank you so much,
            but what if I need to add a boundry line 0.5 pt
            100% “PANTONE \d”
            like this:
            John
            • 3. Re: Re: Can you make a script for modify cells?
              That was easier, than I thought before. Try this:
                  else {
                      main();
              } else {
              function main() {
                  var myColor = "Cyan";
                  var myStrokeWeight = 0.5;
                  var startRow = curSel.cells[0].name.split(":")[1]*1;
                  var endRow = curSel.cells[-1].name.split(":")[1]*1;
                      var curRow = curCell.name.split(":")[1]*1;
                          with ( curCell ) {
                              fillTint = myFillTint;
                              rightEdgeStrokeWeight = myStrokeWeight;
                              rightEdgeStrokeColor= myColor;
                              leftEdgeStrokeWeight = myStrokeWeight;
                              leftEdgeStrokeColor= myColor;
                          if ( curRow == startRow ) {
                              curCell.topEdgeStrokeWeight = myStrokeWeight;
                              curCell.topEdgeStrokeColor= myColor;
                          else if (curRow == endRow ) {
                              curCell.bottomEdgeStrokeWeight = myStrokeWeight;
                              curCell.bottomEdgeStrokeColor= myColor;
                      } // end if
                  } // end for
              } // end main
              • 4. Re: Can you make a script for modify cells?
                Johnwhite Level 1
                Thank you Kai Rübsamen,
                thank you very much, appreciate!
                John
                • 6. Re: Can you make a script for modify cells?
                  Johnwhite Level 1
                  Hi, Kai Rübsamen
                  Can you help me to add a function into it?
                  I want to make the dollar sign in 2014 column apply character style "Bold+Italic", and 2013 column apply character style "Italic".
                  but somethines It will in other row, not always in second row, so I expect it has a dropdown list or checkbox let me tell it dollar sign in which row.
                  for be specify details please see this link:
                  The specified item was not found.
                  Regard,
                  John
