This content has been marked as final.
Show 3 replies
1. Re: RoboHelp 11 / Responsive HTML: Can you remove Index and Glossary from the output layout?
Willam van Weelden Jul 17, 2014 2:10 AM (in response to Tennickly37)There's no way to do this from the HTML5 editor. The only way to get it done is when you dive into the code.
Luckily, I've made a version available with TOC only via http://www.wvanweelden.eu/blog/2014/03/27/adobe-robohelp-responsive-layout-toc-only
Kind regards,
Willam
2. Re: RoboHelp 11 / Responsive HTML: Can you remove Index and Glossary from the output layout?
Tennickly37 Jul 17, 2014 8:47 AM (in response to Willam van Weelden)Thanks Willam. We have customized our responsive layout somewhat, so I'll have to figure out how to make this work. I appreciate the reply!
3. Re: RoboHelp 11 / Responsive HTML: Can you remove Index and Glossary from the output layout?
Captiv8r Jul 17, 2014 9:08 AM (in response to Willam van Weelden)Too bad the Single Source Layout editor doesn't offer little check boxes to turn these off or on as you can in WebHelp.
Cheers... Rick
