Customizing a VScrollBar is not working in Flex sdk 4.6?
$h@!k101 Jul 16, 2014 10:48 PMHi,
I have updated my Flex sdk from 4.5 to 4.6 in my application. I have faced a strange issue this sdk 4.6.
In my application I have designed a Custom VScrollbar for customizing the vertical scroll speed of a mouse wheel to smooth-en the scrolling . This was working fine when using Flex sdk 4.5.
Since I have updated to Flex sdk 4.6, the vertical scroll bar in not visible in UI. Whereas it was visible and working fine using Flex sdk 4.5.
How to make it work in Flex sdk 4.6?
The usage of the Customized Scroller is given below.
In Main Page:
<components:CustomScroller id="homeUIScroller"
width="100%" height="100%">
<s:VGroup >
</s:VGroup>
</components:CustomScroller>
CustomScroller.as:
public class CustomScroller extends Scroller
public function CustomScroller()
super();
this.verticalScrollBar = new CustomVScrollBar();
CustomVScrollBar.as
import flash.events.MouseEvent;
import mx.core.mx_internal;
import mx.events.FlexEvent;
import spark.components.VScrollBar;
import spark.core.IViewport;
use namespace mx_internal;
public class CustomVScrollBar extends VScrollBar
private var distance:Number = 78; // default scroll mover value
* Override mouseWheelHandler to scroll by a fixed amount
* See superclass for example of how this normally works
override mx_internal function mouseWheelHandler(event:MouseEvent):void
const vp:IViewport = viewport;
if (event.isDefaultPrevented() || !vp || !vp.visible)
return;
var delta:Number = event.delta;
var direction:Number = 0;
if (delta < 0){
direction = 1;
} else if (delta == 0){
direction = 0;
} else {
direction = -1;
if(direction == -1 && vp.verticalScrollPosition <= 0)
return;
if(direction == 1 && (vp.verticalScrollPosition + distance) > maximum)
return;
vp.verticalScrollPosition += distance * direction;
event.preventDefault();
Any help would be appreciated.
Thanks In advance.
