4 Replies Latest reply on Jul 17, 2014 8:24 AM by OzSanta2
    How can I add javascript text fields to Acrobat pages from Applescript please?
    OzSanta2 Level 1
      I have a real need to add text fields to Acrobat document pages from Applescript. I can't access the Headers and Footers from Applescript in Acrobat XI. I can set watermarks using the following script, but cannot for the life of me work out how to add text fields. Any advice please?
      Regards
      set TempAttachmentName to "(20140717121212Z)"
      set PreserveFileName to "This is a test"
      set bypass to false
      tell application "Adobe Acrobat Pro"
        activate
        set CountOfPages to count of pages
        repeat with PageCounter from 1 to CountOfPages
        tell application "System Events" to tell process "AdobeAcrobat"
        try
        click menu item "Page..." of menu 1 of menu item "Go To" of menu 1 of menu bar item "View" of menu bar 1
        tell current application to delay 0.1
        keystroke PageCounter as text
        keystroke return
        if not bypass then
        my ADDHeaderFooter(TempAttachmentName, PreserveFileName & " " & CountOfPages, PageCounter)
        end if
        end try
        end tell
        end repeat
      end tell
      on ADDHeaderFooter(The_String1, The_String2, currentPage)
        activate
        set myDocument to document 1
        tell myDocument
        tell page currentPage
        set cbox to crop box
        set item 2 of cbox to (item 2 of cbox) + 44
        set item 4 of cbox to (item 4 of cbox) - 44
        set media box to cbox
        set crop box to cbox
        set theResult1 to my Add_WaterMarkText(The_String1, "IDAutomationHC39M", 12, 1, 1, 1, 0, 3, 10, 3, 0)
        do script theResult1
        set theResult2 to my Add_WaterMarkText(The_String2, "Times", 16, 1, 1, 1, 0, 4, 10, -6, 0)
        do script theResult2
        end tell
        end tell
        end tell
      end ADDHeaderFooter
      on Add_WaterMarkText(cText, cFont, nFontSize, nS, nE, nTA, nHA, nVA, nHV, nVV, nR)
        set Params to "cText: '" & cText & "'," & return
        set Params to Params & "cFont: '" & cFont & "'," & return
        set Params to Params & "nFontSize: '" & nFontSize & "'," & return
        if class of nS is integer then set Params to Params & "nStart: " & (nS - 1) & "," & return
        if class of nE is integer then set Params to Params & "nEnd: " & (nE - 1) & "," & return
        -- 0 = left, 1 = centre, 2 = right
        if class of nHA is integer then set Params to Params & "nHorizAlign: " & nHA & "," & return
        -- 3 = top, 4 = bottom
        if class of nVA is integer then set Params to Params & "nVertAlign: " & nVA & "," & return
        -- offset in points
        if class of nHV is integer then set Params to Params & "nHorizValue: " & nHV & "," & return
        -- offset in points
        if class of nVV is integer then set Params to Params & "nVertValue: " & nVV & "," & return
        if class of nR is integer then set Params to Params & "nRotation: " & nR & "," & return
        set javascript to "this.addWatermarkFromText({" & Params & "});"
        return javascript
      end Add_WaterMarkText
        • 1. Re: How can I add javascript text fields to Acrobat pages from Applescript please?
          Do you have the Acrobat JavaScript API? The second method for Doc will add a field.
          • 2. Re: How can I add javascript text fields to Acrobat pages from Applescript please?
            OzSanta2 Level 1
            G'day
            Unfortunately I don't have the API. My Adobe Reader installation updating to version XI failed, and subsequent attempts to fall back on the X version are blocked by the partial install of XI. Damn Adobe stuff.
            Could someone please post the relevant part of the API to give me some pointers, please.
            I ha mucked about with some information I found on the Web, and come up with the following, which fails because I can't work out how to address the current document with the variable myDoc.
            Regards, Brian
            set Params to Params & "var myDoc = this;" & return
            set bypass to false
              activate
              repeat with PageCounter from 1 to 1 # CountOfPages
              try
              keystroke return
              if not bypass then
              end if
              end try
              end tell
              end repeat
            end tell
              activate
              set myDoc to document 1
              tell myDoc
              set theResult1 to my Add_WaterMarkText(The_String1, "IDAutomationHC39M", 12, 1, 1, 1, 0, 3, 10, 3, 0, myDoc)
              set theResult2 to my Add_WaterMarkText(The_String2, "Times", 16, 1, 1, 1, 0, 4, 10, -6, 0, myDoc)
              end tell
              end tell
              end tell
            end ADDHeaderFooter
            on Add_WaterMarkText(cText, cFont, nFontSize, nS, nE, nTA, nHA, nVA, nHV, nVV, nR, myDoc2)
              #set Params to "var myDoc = app.newDoc();" & return
              set Params to ""
              set Params to Params & "var inch = 72;" & return
              set Params to Params & "var Bbox = this.getPageBox(" & "\"Crop\"" & ");" & return
              set Params to Params & "var f = myDoc.addField(" & "\"Text1\"" & ", " & "\"" & cText & "\"" & ", 0, [72, Bbox[1]-inch, Bbox[2]-2*inch, Bbox[1]-2*inch ] );" & return
              set Params to Params & "f.strokecolor = color.black;" & return
              set Params to Params & "f.richText = true;" & return
              set javascript to Params
              return javascript
            • 3. Re: How can I add javascript text fields to Acrobat pages from Applescript please?
              As a developer you need that document. It is part of the Acrobat SDK, which is free to download. You cannot learn Acrobat programming with google!
              • 4. Re: How can I add javascript text fields to Acrobat pages from Applescript please?
                OzSanta2 Level 1
                Thank you. I checked about faulty Adobe Reader installations, and had to remove several items from the main Library, and re-install version 10.x. I now have the API, and have used watermarks on each page to add barcodes and text.
                Regards
                Brian
