8 Replies Latest reply on Jul 22, 2014 4:38 AM by Johnwhite
    Can you correct my unfunction my script?
    Johnwhite Level 1
      Hi, everyone
      I made a script for add a continued at end of paragraph but unfunction, call you please help to fix it?
      var myDialog = app.dialogs.add({name:"add continueds",canCancel:true});
      with(myDialog){
          with(dialogColumns.add()){
              with(dialogRows.add()){
                 var mySelection = dropdowns.add({stringList:["Continued", "continued", "Cont'd","cont'd"], selectedIndex:0});
      if (myDialog.show() == true)
      main();
      function main(){
      var myObject;
      var myCheckSelection = false;
      if(app.documents.length > 0){
        if(app.selection.length > 0){
         switch(app.selection[0].constructor.name){
          case "InsertionPoint":
          case "Character":
          case "Word":
          case "TextStyleRange":
          case "Line":
          case "Paragraph":
          case "TextColumn":
          case "Text":
          case "Cell":
          case "Column":
          case "Row":
          case "Table":
           myObject = app.selection[0];
           if(myObject != "None")
      else{
        alert("No documents are open. Please open a document and try again.");
      function addContinueds(){
          if (mySelection.selectedIndex == 0){
         app.findGrepPreferences.findWhat = "(.)\\r";
         app.changeGrepPreferences.changeTo = "$1 (Continued)\\r";
         app.selection[0].changeGrep();
         app.findGrepPreferences = app.changeGrepPreferences = null;
          if (mySelection.selectedIndex == 1){
         app.changeGrepPreferences.changeTo = "$1 (continued)\\r";
         if (mySelection.selectedIndex == 2){
         app.changeGrepPreferences.changeTo = "$1 (Cont'd)\\r";
        if (mySelection.selectedIndex == 3){
         app.changeGrepPreferences.changeTo = "$1 (cont'd)\\r";
      John
        • 1. Re: Can you correct my unfunction my script?
          Jump_Over Level 5
          Hi John,
          You wrote a function addContinueds() but you did not call it.
          Your main function could look like this:
          function main(){
            if(app.selection && app.selection[0].hasOwnProperty ("contents") )
                 addContinueds();
            else alert("No documents are open or wrong selection. Please try again.");
          Jarek
          • 2. Re: Can you correct my unfunction my script?
            Johnwhite Level 1
            Hi Jarek
            I try to change it into this:
            with(myDialog){
            main();
            function main(){
            var myObject;
                case "Character":
                case "Word":
                case "Line":
                case "Paragraph":
                case "TextColumn":
                case "Text":
                case "Cell":
                case "Column":
                case "Row":
                case "Table":
            else{
            function main(){
                   addContinueds();
            but still got an error, source code: addContinueds();
            • 3. Re: Re: Can you correct my unfunction my script?
              Jump_Over Level 5
              Watch your copy...paste moves while creating this code.
              A structure suppose to be like:
              //... this is the start of script's job
              var myDialog =
              //... dialog code
                        main();
              //... this is the end of script's job
              function main() {
                   //... function code
              function addContinueds() {
                   //... function code
              Jarek
              PS. I replaced your main() function with mine in previous post.
              • 4. Re: Can you correct my unfunction my script?
                Johnwhite Level 1
                Thanks Jarek,
                now working
                thank you very much
                John
                • 5. Re: Can you correct my unfunction my script?
                  Johnwhite Level 1
                  Hi, Jarek,
                  I made this script:
                  with(myDialog){
                  main();
                  function main(){
                  var myObject;
                      case "Character":
                      case "Word":
                      case "Line":
                      case "Paragraph":
                      case "TextColumn":
                      case "Text":
                      case "Cell":
                      case "Column":
                      case "Row":
                      case "Table":
                    if(app.selection && app.selection[0].hasOwnProperty ("contents") );
                        addContinueds();
                  else{
                  as you taught me,
                  but how can I, make a recall function to dropdown list?
                  like it it can repeat my last selected
                  thanks
                  Best regard
                  John
                  • 6. Re: Re: Can you correct my unfunction my script?
                    Jump_Over Level 5
                    I told about something like this, actually:
                    #target indesign
                    var
                      mySelected = Number( app.extractLabel("mDialog") ),     //     previous selection's set
                      if ( isNaN( mySelected ) ) mySelected = 0;
                      with(myDialog){
                                     var
                                     mySelection = dropdowns.add({stringList:["Continued", "continued", "Cont'd","cont'd"], selectedIndex: mySelected});
                        main();
                    myDialog.destroy();
                    function main(){
                      mySelected = app.insertLabel( "mDialog", String(mySelection.selectedIndex) );     //     to remember selection's set
                      if(app.selection.length && app.selection[0].hasOwnProperty ("contents") ) addContinueds();
                      else alert("Wrong selection. Please try again.");
                      switch (mySelection.selectedIndex){
                           case 1: app.changeGrepPreferences.changeTo = "$1 (continued)";
                                break;
                           case 2: app.changeGrepPreferences.changeTo = "$1 (Cont'd)";
                                break;
                           case 3: app.changeGrepPreferences.changeTo = "$1 (cont'd)";
                                break;
                           default: app.changeGrepPreferences.changeTo = "$1 (Continued)";
                                break;
                      app.findGrepPreferences.findWhat = "(.)$";
                      app.selection[0].paragraphs[-1].changeGrep();     // NOTICE: the last paragraph of selection is targeted
                    There is app.insertLabel() used for keeping previous selection index
                    Jarek
                    • 7. Re: Can you correct my unfunction my script?
                      Johnwhite Level 1
                      Thank you Jarek,
                      Thank you very much, it's so complicate, I thank I can't find a solution to make it happen by myself,
                      so thank you so much
                      John
                      • 8. Re: Can you correct my unfunction my script?
                        Johnwhite Level 1
                        Hi, Jarek
                        I change it into this format (for in case of find-change two or more items) but not work: ---- why?
                        var
                          with(myDialog){
                                         var
                                         mySelection = dropdowns.add({stringList:["01   Continued", "02   continued", "03   Cont'd","04   cont'd"], selectedIndex: mySelected});
                            main();
                        myDialog.destroy();
                        function main(){
                               case 1:
                                    break;
                               case 2:
                                    break;
                               case 3:
                                    break;
                            default:
                                    break;
